madfloyd
Thank you so much, Bhodi!
+ 1. Professional gear is built for accuracy, neutrality and resolution, and mechanically to be robust and fit for purpose, not for those qualities we audiophiles prize such as tone/timbre, harmonic richness, naturalness, sound staging etc.Maybe time to retire the Mogami? I did two decades ago.![]()
I don't disagree, but I don't find it easy. For example, here's what I have in my arsenal:
Source interconnects (all XLR): MIT Oracle MA-X (rev 1), Transparent Reference XL, Burley, Mogami AES (digital cables used for analog on a suggestion from Gary of Genesis)
Preferred is the MIT (deep clear bass, clean treble). The Transparent is rolled off in the extremes and is grainy to my ears.
Preamp->amps (30 feet): Transparent Reference XL (RCA), Burley XLR, Mogami XLR
Preferred for musicality is the Transparent but there are issues with this cable: grainy artifacts in the upper mids, rolled off highs
Speaker cables: MIT Oracle Matrix SHD 90
Bought these to clean up the muddiness that I had with Transparent Ref XL (when I had Wilsons) and sold them.
Nobody is going to lend me a pair of 30 feet XLR cables to try, mostly because nobody has a pair. I can purchase a pair of MIT, but that scares me because you have to specify low/high impedance (no switch for that distance) and if I change amps I'm screwed.
I'm experiencing nasty highs that I feel like I've narrowed down to either the amps, speaker cables or the speakers, so an amp change in my future is possible. I bought the Mogami as just something to try (and tide me over) because I could hear the Transparent single ended cables picking up grunge whereas any XLR seems to have a lot less noise. The Mogami are much better than the Burley (Pass Labs' own brand of cables).
Is that TA MM2 level or the earlier version? Something is amiss if you're hearing grain in the TA????? I might complain more about it being somewhat dynamically compressed, something they have supposedly addressed in the Gen V model.
I don't think MIT will build you a 30' pair of interconnects with anything other than the impedance locked on low. I had a 27' pair of Oracle MA-X SHD built a couple of years ago and they said low impedance for that length was all they could build.
Madfloyd, 30 feet of most cable will roll off highs.
Albert ... I did same thing. Bought 3 outlets, 2 gold and 1 Rho ---- digital gets Rho and amps get gold.
These outlets replaced FIM outlets. I'm very pleased with the sound. Well worth the investment IMO.
I don't mean to wet blanket this direction; but in the last few months Furutech has released their 'NCP' versions of the GTX-D (R) duplex outlet. to my ears it is clearly a level above the GTX-D (R) outlets that I had.
http://www.furutech.com/2015/11/18/12066/
a thread where I describe my experience.
http://www.whatsbestforum.com/showt...7-Furutech-GTX-D-NFC-(R)-outlets-this-morning
if you are wanting the best. these are that.
and further; Furutech also applied the NCP tech to their top-of-line male and IEC plugs for power cords. which I had installed to at least as significant performance upgrade.
http://www.whatsbestforum.com/showt...s-this-morning&p=377221&viewfull=1#post377221
it's too bad this stuff matters so much; but no doubt it surely does.
