I use ultra SS in three's under all rack components and I also use the LP1 puck on top of each rack component, including my amps. The full stillpoint's experience can get rather pricey.
I'm starting to see that! What's a kidney go for these days?
Nelson - I would love to be there, but my wife has decided to return to University, so things are a little upside down - to say the least.
Ask him if we can get them in black and what he recommends for Dag amps/preamps using Dag amp and preamp stands. Thanks!
+1
On what he would suggest for the Dag.
Curious what has your observation been in relation to which item seemed to benefit the most. "speakers?"
Were you able to familiarize yourself with having placed them under your speakers first and then move along trying under other components such as your amps mentioned.
What did you notice when placing them under your amps
The LP1 puck; is there a preferred location to position and what are the benefit's of using this, a pic would be great if you could attach
I did a systematic approach. I focused first on the phono stage and main pre-amps. I think my phono had the most benefit. There is an increase in clarity/transparency. The effect is somewhat cumulative. I usually use the LP1 in the midde of the component and for power supplies I move it over it's approximate location of the transformer inside the box. Stillpoints recommends you experiment. I even use an LP1 on my CA Master Innovation arm board. There to I found t improved the sound.
Speakers might end up benefiting the most, but I need more listening experience before I can offer a definitive opinion. The speakers were my last Stillpoints purchase. I had them in the rest of the system for over a year.
I found the speakers made the most difference in my system, it was a night & day experience.
Thanks - when you made mention to phono stage were you referring to the Pass or your present Allnic or both? My new rack design isn't allowing me to easily add due to height restrictions
After thinking about soundstage increase via ultra 5's on speakers, I have a better description of the improvement...Speaker Disappearing act. The density and extension of music between the speakers improves significantly with the stillpoints versus spikes. x-2's without them are handicapped.
Second answer ,D'agostino stand:
Replace the stand and put directly with 8/32 adapter
He saids that the sound with the ultra 5 directly is Amazing
