La Dolce Vita
I used Elrog 300B on my Lampizator Big 7 before and one tube failed on it. The replacement tube also failed on Big 7 as well. I ended up returning both pairs. That said, the sound was way better than Psvane 101D replica. I didnot even need to A/B to know the huge difference. It has the HF/LF extension as 101D yet with fuller and clearer sound. I think Elrog is like a bigger 101D, with the extention, clarity and fluence of later and reproduce more details.
My system:
Auralic Aries -> Big 7 -> First Watt J2 / Coincident Frankenstein 300B amp -> Voxativ Fullrange.
Voxativ drivers are very revealing and I am sure that tubes easily demonstrate their characteristics through the system.
I therefore purchased a pair of Takatsuki 300B and one single Takatsuki 274B. The rectifiers goes with Big 7 (with 101D replica) and the 300B power tubes go with Frankenstein amps (with Mullar GZ37 rectifier). This combo produce the best treble I've ever heard. The flute sounds so good that I feel it is un-real! I cannot judge everthing else right now since my Voxativ drivers have developed a voice coil rubbing problem and there are noises when playing low strings of guitars and I am sending them in for service.
I haven't tried Takatsuki 300B on Big 7 yet. I need to purchase and put a pair of cheap 300B on Big 7 first to make sure that the Elrog failure is Elrog's problem (which is now reported at forums). But I do believe that they will sound great on Big 7.
I feel that the best 300Bs extend to both HF and LF, and meanwhile provide more and more information in mid range. I think that is the right direction towards a great system. 2 cents.
I appreciate this post... Just a few quick comments...
1) The Elrog 300B tubes are glorious - without question the best 300B I have heard yet in my Lampizator. Having said this... I sold 3 of my 4 pairs as I had 2 pairs fail. Having said this, the dealer stood by me and replaced them. This experience was really unfortunate.
2) My friend BruceLet has the Elrog 300B he uses in his Lampizator. He has had no issues whatsoever with his pair. I also have one pair - no issues (yet)...
3) Numerous times I have compared the Elrog 300B to the Takasuki 300B in the Lampizator. The sound of the Elrog is slightly more full and rich than the Takasuki. The Takasuki is slightly fast and lean, detailed... Really wonderful. Personally I prefer the EML 45 tubes and therefore prefer the Takasuki 300B. But...again...the Elrog tubes are lush and rich. Glorious especially for female jazz vocalist pieces, etc. Takasuki perhaps attuned to orchestral and rock etc.
4) I have also tried Sophia Electric Royal Princess 300B and KR Balloon 300B in the Lampizator. Neither have the effect of the Takasuki or the Elrog. Interestingly I had 2 of the KR Balloon 300B fail on me recently...just like the Elrog. Only having a dealer Stateside is a bit easier in getting support. Still you should know and keep in mind any tube can fail - not just Elrog.
5) I use a quad of Elrog 845's in my customized Cary 211 FE monoblocks. I listen to these everyday and use them hard. They now have had many hours of good playtime and they are glorious. No issues whatsoever. Again, take this with a grain of salt and for what it is worth but suffice to say I am very pleased with their performance to date.
Hope this helps you all...
Andy
