sharkmouth
- Apr 5, 2013
Joe, I'm running my Soulution pre. Meitner dac, & the 2 active speakers:- 800w draw, out of it as well as the apple tv, tv, etc at 25% of draw capacity. It really is a clean, clean sound. Deeper into the depth of the recording could be expressed.......
A Shunyata Triton for everything but the amps, and a Shunyata Cyclops for the amps. If anybody understands power, it is Caelin Gabriel, the founder of Shunyata. Neither conditioner limits current, and the only active component in both pieces is the breaker in the Triton. The Cyclops even omits that in order to give the amps the cleanest possible AC.
I currently have both, along with Zytron Anaconda power cables to the wall. I only have one dedicated 20 amp circuit, and they both use it, and work very nice together. I have just about convinced myself to buy the Typhoon, an add-on component for the Triton. Triton/Typhoon users swear it makes the background noiseless, and music just appears from nothing.
If you love next door to a factory you have different needs than if you love next to a power station.
I agree 100%.
Location is everything.![]()
I used to think that until I bought a regenerator that actually works.Morning, afternoon, evening etc., it's all good. Just good clean power all the time!
Kev - which one are you using?
I have consider a better Power Conditioner for a long time, and I still use my Hydra 8 ver. 2 on my Home theater powering my Denon 5800, the Oppo 83 ES, the MK 350 Subs are straight to the wall, and does an excellent job. I used to have the Hydra8 in my HiFi system and found the Isoclean PT-3030 IV Transformer to do a better Job (took a veal out of the music). The set up was 2 Isoclean, one for the amp and the other for the source, and then change one Isoclean for the amp and the rest on the other. And yes I used the Hydra with my ex Mcintosh 60th anniversary pre and amps, but when I switch to ARC the amp work better straight to the wall. The Isoclean transformer does great with pre and source. I have considered the Audience but not sure with Shunyata.
Hi Joe,
In my system, I have gone the route of an isolation transformer that feeds the 20 amp dedicated outlets in my system. The isolation transformer that I use is from a company called Controlled Power Company. They make many different types of very high quality power solutions and I use one of their K rated isolation transformers. They make K rated transformers in various sizes starting at 5,000 watts and up from there depending on your needs. I use a 10,000 watt model that feeds 12 dedicated 20 amp outlets for my system.
These transformers take a 240 volt input from the main panel of your house that is fed by your utility company and then output 120. I then have a dedicated circuit breaker box that is fed from the isolation transformer. These transformers can be located outside of your house (with an exterior case) or perhaps in your garage. The resulting power quality is a pretty significant upgrade compared to just dedicated lines. The other interesting point about these transformers is their price. When I purchased mine about 5 years ago, including delivery charges it was around $4500. Most of the higher end standalone power conditioners that folks are referring to in this thread cost about this or more - like the latest Shunyata products. I think for example the Triton/Typhon combination is something around $10K. Obviously you need an electrician to install an isolation transformer, but since you already have dedicated lines, the hard work is mostly done.
I now have 2 other audio friends who went ahead and have had isolation transformers from Controlled Power Company installed for their systems and couldn't be happier with the sonic improvements.
I'd be happy to answer any questions that i can about what did for my power distribution system, but I would encourage you take a look at their web site. (I tried to post a link but your forum would't let me do that as I apparently don't have enough posts!)
Hope that helps somewhat
I could say the Isoclean is an Isolation transformer at the plug. Inside there is a huge transformer, a resistor and a switch. Then one power cord goes to the wall and the other to an Isoclean strip or the rectangular 206 or 204 to connect your gear. How does it sound? Not only I experience a veil out of the music, but everything sounds like the system and not the power source. I can hear more micro detail, clear mids and better stage. Again that was against the Shunyata Hydra 8 v2 and not the new Audience or Triton. I thought the hydra with the Mcintosh gear was good but made it all to mellow. One of these days I'm going to put it on my ARC gear to see what happens.
My friend swears by his PS-1220. He says it makes the music smoother and more analog and tube like.
