puroagave
Just being careful. As you point out, the Analysis Plus speakers are configured differently. While they are obviously similar to the Apogees, I assume they have improvements and are made differently, and not having directly compared in my own space, I don't like to be specific. You are quite right re the tonality of the Apogees. Definitely darker in character, lots of bass which in some respects is a good thing since you can position it and smooth it out, whereas panels that start off with little bass extension or a lot of cancellation give you no options.
Did you ever try raking the speakers forward so that they are vertical or even leaning forward more than vertical? The sound is absolutely amazing when you do. Discovered this back in late 80s. The sense of being there in the original venue (with appropriate recordings) is spooky. I still do this with the Martin Logans and any other panel I play
I never tried the duetta past 90 degrees, they were very heavy and 'tippy' i'll take your word on the sound. one of my all-time faves was the Diva, they truly hit the 'apogee' with that speaker. imho, it was the high water mark for all ribbons past and present.
