Not that my MSB Premier is even working (waiting for a replacement renderer) but Keith is right - if using a pre amp you have to go to the menu and select one of the two “volume off” options plus set the “output” to “low”.
Mike - thanks for this. Do you mean “Volume off - Native” instead of “Natural”?
Wow- I am floored at this thing in my system. Even with the small, mono power bases. Just amazing.
I did hear the Premier vs Reference yesterday - much, much different than my last audition. The volume control set properly and more burn-in on the Premier narrowed the two considerably. I would say 15-20% better for the Reference. It has a bit more information, dynamics, and "thereness." I also demo'd the various power supplies and took home the base monos.
I will be trying the Femto 93 clock upgrade for my Premier next - very excited as its card-based. Honestly, I won't be surprised if I sell or downgrade my analog rig. Its that good gentlemen!
I'll bet there is a big difference between the Select and Reference when using them direct to the amp...
So happy for your Keith. It’s totally transformed for me too since first installing. They all need 1-2 weeks of solid run (24/7) and you will be well rewarded.
I’ve listened to them both in identical systems without preamp and yes, the Select is significantly better than the Reference in virtually every way.
Ken, I'm not sure I ever want to hear that demo. Ha!
Seriously though, for my more modest system the Premier hits all gears. In your SOTA one, the Select must be beyond amazing.
Hi guys,
I m interested in a new dac, and the premier tick all my boxes, but indeed way expensive than my budget allow!
Assuming that i skip a preamp in my system, and get the premier fitted with the ethernet renderer and usb input ~ 22usd , do you think sq wise, the premier will outperform lets say a r2r dac=8000 usd+ preamp= 6000usd+ streamer= 4000 usd?
I have an msb dealer here where i live who don t stock any model, and i m lost wich route i should head, knowing that i m willing to replace an excellent devialet200 used as pre/ dac/ streamer feeding an excellent poweramp.
Thks
Where do you live? What MSB dealer doesn’t stock any model? If that’s the case, he’s not a dealer. I would check on this.
To answer your question: yes. The Premier can work beautifully as a VC. Of course a preamp can add some magic, but if push came to shove, the Premier and its VC is the way I would go.
Hi mike,
Thks for the reply.
If i go the premier route , i will be stuck for a while before i can add any upgrade( add a descent preamp, clock, power base), so do you think that the premier will at my stage, and my current system outperform my front end devialet?
The devialet is doing an excellent job as pre and dac now but it s quite an old dac now!
My fear is , invest big on premier and get small on perf!
