This is how I tune my room acoustics, drink whiskey and dance around clapping while using my laser measure to check how far I am about to fall.
LMAO!
I actually took down four at a time, used the clap test, walking around the room...
Not very scientific,
Fair point! The treatments were for the horns. Now that they are gone, the treatments are not as prevalent.
I actually took down four at a time, used the clap test, walking around the room, while focusing mostly on the listening position and continued removing four at a time until the life came back in the room. Not very scientific, but I was maybe a little anxious to get the life back in the room or perhaps it was the whiskey acting that night. [emoji14]
Update on my home system….
I still haven’t received my NAIM NAP500DR amp, but hey, I only ordered it on March. [emoji15]
I received my 552 preamp a few weeks ago and it’s been breaking in nicely and is quite the step up in sound and weight (!!) over the 252.
I received my 555 streamer, but no power supply. [emoji848]. So I can’t use it. I should get two power supplies next week. I decided to go for the dual PSU setup.
I’ve found the Wireworld Starlight 8 Ethernet and Starlight 8 SPDIF (digital RCA) to sound the best from my N20 to the NAIM streamer. I don’t understand this, but it is what it is. NAIM is weird.
All NAIM FRAME racks are in and looking awesome. I have the custom shelf from Europe which sits on top of the NAIM FRAME for the giant Kronos Turntable. I may replace the one Quadrasphire rack I’m using with one more NAIM FRAME next year.
I’ve spent the past month or so experimenting with cables and power conditioners. The Denali 6000S V2 is what I’m using now and sounds the best. The synergy between Shunyata and NAIM is undeniable. I would love to see Shunyata make “for NAIM” cables. Ultra low capacitance speaker cables, 4 pin and 5 pin DIN’s, etc. But I’m likely dreaming….
For cabling, I’m using all NAIM SuperLumina, except for one custom made XLR to 5 pin DIN cable I had made by Chord Cables for my Doshi Tape pre to the 552.
For power cables, I tried AQ Thunderbird, Firebird, Dragon, Nordost Valhalla 2 and Odin 2 and Shunyata Alpha V2, Sigma V2 and Omega V2. My favorite with NAIM was Sigma V2. I found the lower noise floor and meat on the bones sound works very well with NAIM gear. I found NAIM does not like silver on the power too much.
Last night I experimented with the Nordost Grounding System (QKore6). I was frankly, blown away by the results. I posted my findings on another thread. I will be getting two QKore6’s and might get a QBase8 to tie together power and signal grounding.
I had an awful time finding the route cause of the hum between my Trinnov front L/R outputs (XLR) and the NAIM 552 Cinema Bypass input (5 pin DIN). I tried everything and frankly found the simplest solution to be the best: 5pin DIN to RCA, using a Cardas RCA to XLR adapter I had laying around and then a long run of XLR (some old Kimber) to the Trinnov. Voila! No hum. Trinnov recommends another RCA to XLR adapter called a 322x 3-pin XLR female to RCA female adapter, so I’m going to try those when they arrive from Amazon on December 1.
I should be seeing my Kharma Midi’s with upgraded OMEGA drivers (from the Veyron series) before the end of the year.
As for my NAIM 500 amp? God only knows. I called NAIM UK and they said “ain’t shipping this year buddy.” Ugh.
Post some new pics Mike and I bet this was said in the most respectable British accent right? Red highlighted below.
Sure!
What the hell Mike, you couldn't have added a few more components in there...
Looking good!
I thought the same thing Randy. I guess Naim components are very multi chassis design centric. Looks great though with the symmetry.
Looking good!
Coming together nicely Mike!
