the professor
Late 90's I had a 6 pack running Naim DBLs. A bunch of boxes for sure.
I saw on a previous post that you have tried IsoAcoustics Orea Bordeaux footers.
Would you hazard a guess as to how they would work under a Pass Labs X350.8 on the floor? The X350.8 is currently just on the floor.
Thanks
Mike, have you ever tried driving the Ktema or Accordo Essence speakers with X 0.8 Pass Labs amps?
I am just wondering uf they are a good match.
Thanks
Mike,
Do you know if the 282 preamp requires external power supplies or can it be powered directly from a NAP300DR?
It requires the little NAPSC box. External power supply (HiCap or SuperCap) is optional with the 282 preamp.
Well, I ordered 5 Naim pieces… had a good chat with Mike. No matter how much I spend myself on gear I still wont be able to get half the exposure that Mike gets, his willingness to honestly and candidly share his opinion is refreshing. Now lets see how long Ill have to wait.
Well I did get the Super Lumina cables as I did read that it matters. My Reference speaker cables are Audioquest Firebirds but they are terminated with spades so that wouldnt work any way.
I had a time crunch so I decided to land right in the middle of the line up… The NDX2, 282, 250 and HiCap. I considered the SuperCap but if the system works out then Ill just jump to the 500 series which makes the SuperCap obsolete. We will see how it compares with my Chord stack and Blades.
WOW. that used to be my dream system. I had 52 driving 4 x 135's active SBL's. Distributor would not bring in DBL's and after we moved to a bigger house, the SBL's were not large enough so went a different direction.
Well, got some bad news today. Looks like the NAP250 I've ordered will be terribly underpowered and mismatched with my Blades. Minimum recommended is the 300, or ideally the 500. Oi vey! and here I thought I was just dipping my toe
