Kuoppis
- Jan 19, 2015
As far as I understand the whole nanotubes / graphene technology, the nanotubes - and now the graphene - are used as an additive to the resin that holds carbon fibre together (carbon fibre by itself is a soft fabric; to make it stiff you need to soak it in resin; adding nanotubes powder changes the mechanical properties of the resin). As the woofers' diaphragms are made from aluminium, it is not possible to coat them. The only part of the woofer where graphene could be applied, is the dust cap, which is made from carbon fibre.
Thank you for the explanation, Elberoth. This was really helpful. It was indeed unclear to me how graphene could be used with the aluminum woofers.
