Lumin X1 Fiber Optic Network Discussions
An audio manufacturer recently stated their preference for StarTech SFP module in their (non-Lumin) setup based on subjective SQ comparison.
We have not tested this brand for compatibility. X1 users who have used it please let us know:
https://www.amazon.com/StarTech-com-Cisco-GLC-LH-SM-Compatible-Module/dp/B00BUBW2SQ
[FONT=&quot]I have used these in several older Dell Servers and they were easy to install and setup, and work perfectly. I added several of these to connect to a Ubiquiti 10gig aggregation switch and everything communicated with each other without issue and at the speeds expected.[/FONT]
[FONT=&quot]Also I have used products from Gtek multiple times now and everything has been smooth and simple.
[/FONT]
https://www.sfpcables.com/10gsfp-transceiver-axs85-192-m3
Also i check there are all good in compatible with cisco: https://www.sfpcables.com/10gsfp-transceiver-axs13-192-10
platform is much cheaper than Amazon
I have tested Lumin X1 compatibility (works normally as expected) with a pair of the StarTech 1000BASE-LX 1310nm SFP modules above, along with this LC-LC duplex single mode Corning fiber:
https://www.fs.com/products/68296.html
to this Cisco SG112-24-NA SFP switch:
https://www.amazon.com/SYSTEMS-24-Port-Gigabit-Switch-SG11224NA/dp/B00VPT8XSQ
Peter,
It was good to meet at the Hong Kong AV show this weekend. As i told you, your involvement here is stellar. I know of no other manufacturer who has a rep who is so helpful to forum members. On that point alone, Lumin is worth supporting.
Cheers
howie
Peter,
Cheers
howie
+1
Peter,
Cheers
howie
Thanks for the message! I'm glad to see and talk to our users and other visitors.
This year in AV Show we used a Lumin X1 with the setup in post #183, with music stored in a Lumin L1. It is directly connected to a pair of our Lumin (class AB) AMP in bridge mode via XLR balanced interconnect, driving Troy Audio speakers (made in USA) whom we partner with this year.
At one time someone played Michael Jackson - Beat It. With renewed controversy surrouding him, I wondered whether it'll drive people away or attract them to come in. Then all the seats in the room were taken.
Before the show we verified the Roon Core was running properly on the NAS we prepared for the show (in case any visitor asks about using Roon with Lumin). On the day of setup, the NAS died.
Regardless of the controversy, Michael Jackson's music is timeless and wonderful especially Eddie Van Halen's guitar licks on "Beat It".
Ordered the parts and switched my X1 to optical connection (surprisingly easy, took less than 10 minutes). Sound wise, definitely hearing deeper into the recording already with little burn in. Totally worth trying, costs about as much as low end usb digital audio cable.
Peter,
I have a 75' copper Ethernet cable run to my stereo component area. With all that copper Ethernet cable, would I improve the sound quality by using the optical port of the X1? Is there a difference in the sound quality in using a gigabit switch with a fibre port vs. the FMC method?
Thanks,
Brian ...
Yes, it may sound different. Based on the feedback, there are more users preferring the optical network connection than those preferring copper Ethernet.
The X1 built-in SFP port is indeed better than the FMC, because it is driven by the high quality X1 LPS, and there is no need for the signal to go through another copper Ethernet cable (as in using a FMC).
For a sample configuration please refer to this:
LUMIN - Fibre Networking
A Lumin X1 user on whatsbestforum on X1 fiber networking: Lumin X1: Enabling an Even Simpler Yet Better Sounding System | What's Best Audio and Video Forum. The Best High End Audio Forum on the planet!
This system was already marvelous in sound, the best by far I've had in this room. But the combination of better vibration protection, purer powerlines, and the fibre optic connection between the switch and the Lumin moves the performance up to a level of naturalness and a freedom from distortion which I had to hear to believe. There is simultaneously an increased smoothness and transparency to the sound without any real detail being lost. What is lost is distortion which was adding just a bit of edge that was not really noticed until I heard its absence.
I did A/B the Lumin with a copper ethernet link, then with the optical link. That change in itself is a significant part of the transformation I'm hearing.
Changing from copper ethernet to the fibre optic connection between the switch and the Lumin X1 meant even less "grunge" in the background, blacker backgrounds, even less high frequency digital nasties, and a generally more open sound. This is true regardless of the quality of the program--it applies from low-bit-rate internet radio up through high-res programs from Tidal or Qobuz. Lumin and the reviewers who have commented on this type of connection's performance are correct. This is better yet than an ethernet connection, which itself was better than a single Wi-Fi link in the streaming connection.
I can heartily recommend that those of you who have a Lumin X1 (or another streamer with a fibre connection potential built in--are there any others?) try this right away. The money spent, at least in my system, was way out of proportion to the audible improvement. What was obviously already a top streamer before in terms of sound quality is now at another level entirely, qualitatively superior to anything I've previously heard in network streaming.
If I use the fiber optic connection, would having the Uptone Etherregen switch upstream of it provide any additional benefit? Apparently, it improves SQ for copper ethernet. What do you all think?
