Wait, I found one. The L2 Nordic
	Peter..with the latest upgrade tonight...am i correct, when reading your explanation of what is NOW taking place when i listen to the Tidal 'Master' albums with the Lumin app, is the final unfolding and true MQA listening..?..i have been listening tonight to many Master tracks and what i hear sounds so much better then the same track on Roon.....every track...
Yes. No matter you use Lumin app or Roon, full unfold should take place. Read the front panel and check that you see MQA is displayed in both cases.
Another MQA question. I keep the front panel display turned off. Will the app display the MQA information?
Peter..when using the Lumin app the player does reflect the MQA status on the front panel screen but does not say MQA when using Roon. The sound is ..as expected...not as good either with Masters albums...
I think that's the first ceiling-mounted install we've see Ritmo - congrats!
That must be down to browsing on a tablet/phone device (with an orientation). On my PC they are both upside down.Yes, not only is the Lumin now fully MQA enabled, it also defies the laws of gravity. ��
Interestingly, the small picture shows the Lumin upside down but the larger view shows it normally.
