Peter - did this update improve the sound or am I imagining things?
Firmware 9.05 improves MQA sound quality for Lumin A1 / T1 / D1 analog outputs. Were you hearing improvment from A1?
Out of curiosity how would a Lumin unit (I guess U1) be set-up in a system with Tidal and Roon.
- Assuming you have a MQA capable RAAT DAC. Would you set Tidal up in Exclusive Mode and Pass thru. Open the Roon ap and somewhere select the Lumin U1 and then endpoint be whichever DAC?
- For a MQA DAC that supports RAAT, it means it has Ethernet input and is Roon Ready, you don't need Lumin U1 unless you find that the DAC sounds better from USB or AES than from Ethernet, or it is one of the two brands of MQA RAAT device exceptions described below.
- For a MQA USB DAC, Lumin U1 will detect it is a Full MQA decoder, and automatically goes into MQA passthrough mode.
- For a MQA Renderer such as Berkeley Alpha DAC Reference 2 MQA, Lumin U1 does the MQA Core decoding to 96 or 88.2kHz by default, then Berkeley does the rendering to offer full benefits of MQA.
- For a non-MQA DAC, Lumin U1 does MQA Core decoding to 96 or 88.2kHz by default.
- Lumin U1 and all models of Lumin players support RAAT and show up in Roon as Roon Ready endpoints.
- When you use Roon, you enter the Tidal account details inside Roon, and do not use Tidal desktop app. Roon cannot do any MQA decoding currently, and therefore has no option for MQA passthrough - in effect Roon passthrough MQA by default if no DSP or volume changes.
- Note that two other popular brands of Roon Ready MQA devices can either only decode MQA or use RAAT, but not do both at the same time at the time of this post. They need more time to fix this limitation. Lumin does not have this limitation, and offers MQA decoding even when used with RAAT.
how the Lumin and Berkeley DAC would work together. Which Lumin output is used in that instance? Not USB I assume.
Peter - Many thanks for clearing this up! I wondered about this and I'm sure a few others as well.
I wondered if anybody cared about this.![]()
Status update on MQA certification for M1: it is progressing well.
By the way, a competitor released a $49.99 MQA firmware upgrade for what Lumin gave for free...
Lumin M1 is now MQA certified, making it one of the rare MQA Roon Ready integrated amplifier that actually decodes MQA over Roon RAAT (*)
In Firmware 10.2 for Lumin M1, the non-MQA digital processing path for amplification is optimized as well, so it will sound better than before, MQA or not.
So the whole Lumin network player/transport product line S1 / A1 / T1 / D1 / D2 / U1 / M1 are now MQA certified.
* There are other MQA Roon Ready products from other manufacturers that cannot decode MQA when playing from Roon.
