The XU216 itself is not the culprit, its role is like the CPU in your computer. The firmware running on the XU216 has to be programmed carefully to avoid such pops. As a workaround you may force the U1 MINI to convert DSD to PCM by enabling Volume Control. So the DAC only handles PCM and it won't need to switch between PCM and DSD, thereby avoiding any potential DSD-related pop.
Please make sure you're running the latest firmware for the D90 DAC.
There is no pop sound in T2 when switching between any format.
