From a Lumin X1 user: Lumin X1: Enabling an Even Simpler Yet Better Sounding System | What's Best Audio and Video Forum. The Best High End Audio Forum on the planet!
I'd call it greater clarity and immediacy, lower-yet apparent distortion, together with larger-yet soundstaging in all dimensions and more solid imaging--the usual audiophile desiderata. This effect seems audible on all signals from low-quality internet radio streams up through high resolution programs.
Even at extremely low volume levels (didn't want to wake my sleeping spouse, of course!) of between 8 to 10 on the 100-point volume scale ("normal" high volume for me in this system is about 72 or so), the added clarity and transparency were amazing. It's like I suddenly had Quad 57s or some other speaker known for extreme transparency even at very low volume levels.
The Leedh volume processing can be toggled on and off at will within the Lumin App for comparison. The switchover takes less than five seconds. Thus, pretty good A/B testing of the Leedh processing is available. (This assumes, of course, that Lumin has not somehow "dumbed down" the volume control when Leedh is not engaged in the new firmware. There's no way to quickly A/B the new version of the firmware with the old version.) The difference is the proverbial "night and day." And this is even though the direct connection before seemed surprisingly sonically purer than using the special relay-controlled volume control of my Benchmark HPA4 "preamp" which I thought was pretty special indeed at the time.
The combination of upsampling/resampling everything via Roon's DSP engine to DSD 512, Leedh Volume processing by the Lumin X1, and the elimination of the DSD to PCM filtration in Roon has enabled my system to push past some threshold into a realism I've never before achieved. On much program material, there is an absence of artifacts and a see-through realism which allow me to suspend disbelief to an extent never before possible. This is even true for much low-bit-rate internet radio material.
