stax
Are the benefits of using the X1 (with Leedh) connected directly to a power amp limited to playback using the Lumin app only or would they also extend to playback using Roon via the X1?
Why don’t you try going directly from the Lumin into your power amp and use the Lumin volume control with Leedh processing. That’s what I’ve been doing with my X1 and it sounds quite good!
Here is what Lumin recommends insofar as options for use of Leedh processing:
LUMIN - Leedh Processing
That part about be ‘no longer bit perfect’ is what I’m after.1. If you use the volume of an integrated amp, you should generally set the U1 MINI to disable the Volume Control (such that volume is 100 with max volume % at 100), otherwise the Lumin output to the DAC will no longer be bit perfect. For Lumin digital output (not analog output like those on Lumin X1 or T2) 100 is standard, it is not hot at all. If you find Lumin digital volume 100 being too hot for your DAC, it's your DAC + amp + speakers that is too hot for your desirable listening.
2. The Max Volume % feature is primarily used in scenario where you bypass the preamp or exclusively use the Lumin app volume instead of the preamp or integrated amp volume control. You can experiment with these but if you still need to use the integrated amp volume for other purposes, then don't. You either exclusively use Lumin app volume, or exclusively use the integrated amp volume, mixing them for different purposes will be error prone.
3. If your DAC offers a lower gain setting (e.g. -6dB), you should try it. Only if it still sounds too loud to you should you decrease the Lumin volume. Note that if you have volume control enabled in Lumin U1 (MINI), DSD will be converted to PCM before outputting to the DAC.
Good question, and something I tried. I would have to switch the toggle in the back of the amp for the unbalanced and balanced connection depending on if I was using my TV/Vinyl vs the Lumin for that to work. Maybe that can work, but from what I read, the Home Theater bypass *should* do the same thing theoretically as it is supposed to go through none of the circuitry in the pre-amp to process the sound. I will try the direct connection again, and see if there is an audible difference and then see if it is worth flipping the balanced/unbalanced toggle everytime I want to switch from the streamer vs any other media I'd want to listen to.
Hi , i just tried using the leedh from Lumin X1 , with my Accuphase E-470 as it is possible to only use its amp section. I wasn't prepared on that big difference in sound it made , everything became more clear as well as much better differentiated in depth as well as between individuals playing in a group. Its so good that i can't imagine going back to use the preamp section of the Accuphase E-470 again. And now i am beginning to think about getting an amp only as Lumin Amp , or Gryphon Essence..... i might convince my dealer to let me get loan of one to see what it can do in my system. Although i am still bleeding from the purchased of Lumin X1 , but its with a smile on my face.
