I second TotalDAC USB cable. Terrific cable (the best I've heard in my system) and if you consider excellent value for maney ratio, it is a no brainer.
Do you know what is the best sounding or technically advisable preferred length (as far as I know we can get between 25cm and 2m length)?
Anyone tried it with Devialet?
Steve Nugent always advised 1.5m to 2m. Longer than 3m and you get latency issue and shorter than 0.75m and there coulbe be signal reflections? I think that was what he said.
I see RCA SE ouput at the back.
Amanero for sure.This week is big for me. I will get my Lite 7 DAC. I am soooo exciting.... Yess.
I have a question. Which USB drive should I use for windows 8.1? I mean There is two module on lampizator.eu
1) Amanero Module
2) Exd Module
1) Amanero Module
2) Exd Module
hi guys , i think you should look at this one:
http://www.computeraudiophile.com/f...converter-magic-%96-no-true-26091/#post473592
