cmalak
- Apr 10, 2013
If you are considering the Pulsars, I would also look at the Dynaudio C1 Sigs.
In the $10K and under range, I would also consider Devore Fidelite speakers (excellent with tubes):
1) Under $5K, his stand mounts, the 3XLs, are awesome
2) The Gibbon 88 are maybe $6.5K I believe and are excellent all around speakers
3) A tad over $10K are his new X (as in Ten) speakers
www.devorefidelity.com
He usually demoes his speakers with Shindo, Leben and Line Magnetic amplification but the point being he typically designs speakers with benign loads (nominal impedance is usually 8 ohms and most of his speakers have relatively flat impedance curves and spend most of the frequency band above 6 ohms). So they should play very nice with your Snappers.
