heres some perspectives. im real interested in these . but im not sure if im ready for floorstanders yet. from the couple people i spoke to who have experiece with these and the pulsars, its the normal give and take, of monitors to floorstanders. pulsars image a little better,and perspectives go a little deeper. but according to both people the sounstage is huge on both.
Impedance: 8 ohms nominal, 6 ohms minimum.
System impedance indicates whether the speaker presents a "hard" or "easy" load on the amplifier. True 8 ohm speakers are less amplifier and cable sensitive, and partner well with a broader range of amplifiers, including tube designs.
Crossovers: Asymmetrical Infinite Slope Crossover at 2 kHz.
Constructed of specially selected components, Each individual network is precisely adjusted, resulting in a virtually perfect match to the original prototype.
The steep filter slopes ensure good acoustical behavior in the crossover regions, with a minimum of acoustical interference, along with low distortion and wide dynamic range. Driver acoustic responses are in-phase throughout the crossover regions.
Frequency Response:
The Perspective delivers a very smooth and even response over a very broad listening window. Unlike conventional low order crossover designs, the speaker retains its sonic balance over a wide angle both vertically and horizontally. This results in a higher level of fidelity than a simple on axis measurement can reveal.
Listening window response: 2dB from 35 Hz to 20 kHz.
Dimensions and weight: 36" (915 mm) H x 8.5" (216 mm) W x 13" (330 mm) D.
Shipping weight approx 81 lbs. (37.6 kg) Each & approx 20 lbs (9.07 kg)for the stands.
SPECIFICATIONS
Specifications cannot properly describe the ecstatic experience that awaits you when you sit down to listen to your favorite music through a pair of Joseph Audio speakers.
Frequency Response:
SPECIFICATIONS
