adrian0115
- Oct 23, 2015
Type
2-way vented bookshelf loudspeaker
Drivers
6 1/2" (165mm) “W” cone midbass
11/4" (27mm) pure Beryllium IAL inverteddome tweeter
Frequency response (+/-3dB)
46Hz - 40kHz
Low frequency point (-6dB)
41Hz
Sensitivity (2.83V/1m)
89dB
Nominal impedance
8Ω
Minimum impedance
3.9Ω
Crossover frequency
2200Hz
Recommended amplifier power
25 - 150W
Dimensions (HxWxD)
15 3/16x10 3/8x13 3/4"(385x264x350mm)
Net weight
33lb (15kg)
The specs of your speakers look pretty good, even for the Job 225. I'd opt for the newer amp, but that's just me.
Joe,
You mean the monos or integrated?
	 as to what the possibilities may be.
