Not to dredge anything up, but I'm curious why no one has addressed what appears to Jinjuku's main point?
If I understand correctly, he's saying that when comparing ethernet cables you're not really comparing cables because the
track is already in the buffer. That is , when you change cables, you're still hearing the same signal as you were before the
cable was switched. Do I have this right?
"Tidal can load an entire track into their buffer in 6-7 seconds on my 100Mbps Internet connection.
In both instances I can pull the cable and the entire track plays. Did my sound get worse, get better, stay the same when the cable was pulled?"
This actually doesn't meet my experience, as when I pull the cable, the track will only play for a 4 seconds... Am I misunderstanding something?
Can you explain this, Jinjuko?
And finally, I listened carefully, for days, comparing the AQ Diamond, the Sotm with filter, and Supra cat 8. They each have their own sound. The AQ is very resolved, refined, delicate-- almost restrained in a good way. The Sotm is a little more dramatic in the bass and less resolved. The Supra is warm, smooth and another several degrees less resolved.
I have no doubt I could pick the Supra vs the AQ, blind, on my system and on music familiar to me.
