Must be an echo in here.......haha.
He says it straight out that the controls on the sub woofer will only add more delay to an already delayed and out of phase subwoofer. Being 360 out of phase, as in measuring well on a computer screen isn't going to help things in reality.
Regardless of time delay isn't 360[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]º out of phase actually in phase?[/FONT]
Under test conditions of a steady tone maybe.Regardless of time delay isn't 360[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]º out of phase actually in phase?[/FONT]
Great video!
Awesome presence/life sensation. :thumbsup:
I share your dilemma.![]()
I've never employed an active x-over but it's interesting how some of you reach some of your conclusions. I don't find integrating a sub to the mains a disaster but rather quite the opposite Although I do find integrating and tuning subs a potential royal pain in the ass as it is perhaps the most difficult and tedious thing to accomplish. But it can and must be done.
I recently installed a second Rythmik E15 subwoofer on the left to match the one on the right. The one on the right I'd been fine-tuning for several years and had just gotten it soooo fine-tuned just days before installing the second sub.
Everything about the 2nd sub is identical to the first in the way of symmetry to within 1/4", cables, custom footers anchoring it rock solid to the subflooring, mass-loading, each on its own dedicated 20 amp outlet, line, circuit, the settings, etc.
Regardless, since installing the 2nd sub I've spent just a bit of time attempting to fine-tune both subs (identically) and as things stand, I do not consider the subs as fine-tuned as could be but for now I call it close enough.
BTW, I'm rather pleased with the Rythmik subs' performance. But only after much fine-tuning. The subs are mated to a pair of full-range VMSP RM-40 speakers and I've got the subs' x-over set around 84Hz. And though each main speaker has two 9" inch woofers plus a 9" passive radiator I still find the RM-40's bass to be the speaker's weakest link.
Yes, I too believe that subs are necessary to complete most systems.
I do question your setup in trying to mirror match the exact location of your subs.
If you look into multiple sub setup/placement you find many approach it as placing subs in non symetrical locations. Doing so helps to to smooth the bass, working with the rooms peaks and nulls for better integration.
A good read on this can be found from Audiokenisis/James Romeo on their "Swarm" subwoofer system.
This may or may not be helpfull in your application but it does shed some light on a different approach.
No, I did not watch your videos as I personally find on line videos to be very subjective.
You truly may have found the best place for your subs, in your room, to your liking.
As to showing you, If you look at the AMROC room mode calculator you can see where the peaks and nulls appear in any given room.
It is my understanding that placing two or more transducers in the same peak/null location has minimal additive effect. Thus I referenced multiple sub placement from Duke LaJune AKA "The Swarm". It has received accolades from The Absolute Sound.
Some find this approach beneficial.
If you enjoy the placement you have then that's great, just enjoy.
And what in high-end audio isn't very subjective?
So you like to hypothesize? Nice. But isn't that even far more subjective and a bigger waste of everybody's time than listening to music?
Enjoy your music, as I have previously stated. Or perhaps you missed that part.
Thanks, jade. Much appreciated and don't forget... The hypothesizing mind is a terrible thing to waste - especially on others.
How does the saying go? You can lead a horse to water but you can't make him drink.
Perhaps with all your wisdom you may wish to write a book so the rest of us can learn from your vast knowledge and experience. Just saying.
Or is that hypothesizing?
