Mike Gillespie
- Apr 8, 2013
JL Audio is coming out with a crossover (all analog) that will be significantly less list price than the Bryston, and they say it will have far more features.
Great thread, First post. I'm using two REL subs connected via their speakon cables. I'm one of those guys who tacked subs onto full range speakers and is happy with the results. I want to know more about the importance of using an active crossover. Some speaker manufactures are designing built in subs. I recently heard some Vandersteen's (don't remember the model but they were about $45k) and they sounded amazing. Are they using active crossovers built into the cabinets?
PS Im also running Dirac Live room correction.
If you are going to use a sub in a 2 channel system, do yourself a favor and purchase an active crossover.
Tacking a sub on at the bottom of your full range speakers, is a comlete disaster. It muddles the bass on certain Cd's and will only sound good on Cd's that you have the sub balanced for them alone.
(I have SF Elipsa's and JL subs)
I dont agree. I found active xovers reminded me of digital room correction from the likes of Anthem's ARC and McIntosh's RP. Not bad, but definitely not good. Dynamics were squashed, and music just lost its realism.
I use two F110's with my Sasha's and am getting great results without actively crossovers in the way.
Just goes to show, before believe everything is absolute, you shoud hear for yoursel. Not everyone's preferences are the same.
After adding a second sub I became convinced stereo subs will be with me for life. The subs added so much more than bass. I'm getting better depth, air, punch, and sweetness throughout. They let me get away with smaller speakers, they help compensate for room problems, and they add flexibility with speaker placement. The thought of having to use an active crossover is messing up my game plan. I just don't want another component with things to adjust. Everyone loves their JL subs but I see a lot of people having trouble integrating without the active crossover. Radioactive you keep the dream alive.
I think that people sometimes get talking about active or not active when almost all subs use an active crossover --- the discussion is really whether or not to use a high pass filter to eliminate the lows in the main speakers or to run them full range.
Powered subs (99%) use an active crossover because they filter out the high freq before the amp built in.
I use a separate active crossover because it gives me quite a bit more control of the sub to better integrate. However, I choose not use the high pass part to roll off the main speakers because I find that it sounds better. I run the full signal to the main speakers.
So you're saying that either way the main speakers are not running full range because you are sending the high pass to them?
IMO I get a better musical system if I don't do anything to the main speakers and augment the base w a sub. Sometimes it's only below 30hz and sometimes it's below 70 hz.
Bryan how do you have your subs connected?
KingRT10 - Welcome to AS!
I agree that an active crossover is key. I have found that the way Rel integrates their subs can also be quite effective.
Bill13 here has mentioned a lack of bass with his Elipsa's. Can you give a little more info on what crossover you are using and which subs you went with? F110's?
