a.wayne
you might be right. but I ran out of floor space.
A blessing for dealing with those not able to understand the power necessary for real world dynamic's..
Hi Bart,
Think I've dropped the idea on having CD's/SACD's ... so did not remember to add this.
Well, a stack of dCS Vivaldi, comprising of the Transport, DAC, Upsampler & Master Clock should do. Its always so nice to play around with DREAM SYSTEM.
For Video playback, the full mod ModWright Oppo UDP-205 will do just fine. In fact, I had it a couple of weeks ago, before Chinese New Year and I must say, Dan's work surpasses my expectation. Good enough to be an all-in-one in a much humbler setup.
In a more REALISTIC twist of things, after adding the ModWright UDP-205, would be adding the Magnum MD108T when my Devialet O'dA comes back from France after the Core Infinity upgrade, I am thinking of switching the speakers to Wilson Alexia, I or II's, depending if I can really hear that difference as spelt out by the reviewers. The Radio D-3.1 should not have a problem finding a new home as its all about pricing to sell. Now, if the O'dA will go for my targetted pricing, Dan D'Agositino Momentum 4 piece may be in the running. If not, the Progression will do just as well, albeit slightly painful to the pocket.
Cables? Well, the Audience SX 24 speaker cables will haver to be kept back into the box as the Wilsons done take Bananas I was told. So in come a pair of Transparent Reference. And not the ridiculously expensive Magnum Opus/Opus. Just the mid range Reference will do. This last part is in the planning stage and by no means THE action. The Oppo and Tuner is a sure do.
Oh well, thats all for an exciting 2018. I guess, its Never Say Never Again .... what an "U Turn" hobby this is. Not to see if I can find myself out of the small den.
Cheers
I kinda like my little old system.......and my choice(s) of amplifiers, dart 458's + Lamm ML3 Signatures (just arrived) is right up there.....and then there is the whole 800 pound gorilla of the building and room to consider. you start there and I did that part. MSB Select II + a couple of Studer A-820's and the new AS-2000 tt. the 1500 pound per side, twin tower MM7's aren't the sexy name, but humble most other choices and have unique coherence aspects at the top of the food chain as well as the 97db, 7 ohm efficiency to allow those ML3's to really sing.
Mike,..another beautiful photo of an amazing system; love how those amps and overall setup of them speak volumes,...BEAUTIFUL!!!
this morning (with the dart in standby all night) things seem back to normal with the dart, as all the cables and especially the grounding cables have settled in and sound right. i'm hearing typically excellent meat on the bones and degrees of tonal density. we will see as I revisit some different recordings how we are doing.
right now i'm not compelled to put the ML3's back in, it's more i'm enjoying a more open, relaxed, effortless and spacious musical world. but hey; this has been my environment for years so no surprise. the same piano digital track I had on last night that was not quite doing it, is now just ducky.
i'm happy to switch these posts (if I should) about the ML3-458 experience to it's own thread as I don't wan't to screw up this 'ultimate system' thread.
Good to hear Mike. It sounds like the big 458's are just too delicious sounding and "right" sounding to ignore. Have you ever tried big tube amps? VAC 450iQ monos for example. ARC 750SE monos? There is probably a good synergy between the bass driver amplification and the big Dart's.
I've had big CJ's (LP275M) and the Berning 211/845's in my system in the last few years (since I had my dart 458's) to name a couple. and I've heard lots of big tubes at shows multiple times. I typically like them to various degrees.
but I always find I easily prefer the overall performance of the big darTZeel's to any high power tube amplifier. the lower noise and greater speed and control of the darts, along with it's refinement, tips the balance. big tubes sound like big tubes to me. OTOH the ML3's bring a degree of musicality to my system a few degrees of magnitude greater than those big tube amps so offer a few steps farther alternate viewpoint.
if I lived with a few of the above named big tube amps you never know what that might do, but I've never really been even much tempted by them. OTOH when I've heard the ML3's in other systems it has always grabbed me. and it grabs me now in my system too. this is an emotion based hobby, and right now the ML3's and big darts both do it for me. and I've yet to hear anything very close to either at their strengths.
Hello,
I hope you will not mind a newbie view
I am taken by musicality, precision, technology but also design and execution.
As I transition between residences, I am fortunate to be in a position to put together my ultimate system.
For a small room:
Devialet Expert Pro -> Magico Q1
For the main room:
MSB Select or totaldac d1-twelve -> Naim Statement -> Magico M6
best,
gn
Thank you, Mike, I have read whatever I could find across a number of forums and very much appreciate your contributions and sharing of the Select II experience!
I will most likely have to make a choice between totaldac and MSB based on auditioning d1-seven and Reference. I will be reaching out for help
best,
gn
Good to see you got tempted and took my VAC450 suggestion. The ones with iQ are very nice. No fussing with bias. Hopefully they work out for you.
we will see; i'm listening to the VAC Statement 450's (not the iQ versions) now. but I did not pursue them (or turn them down either).
my friend made me an offer I could not refuse, partly with all the suggestions to try 'big tubes'. he said come and get them and try them for a while......and see what you think.
they sound 'big' and 'liquid' and 'authoritative' as you would expect and seem to perfectly integrate with the active bass towers of my MM7's.
if the darTZeel 458's and Lamm ML3 Signatures together was crazy, not sure the word we use for then adding the VAC Statement 450 mono blocks. 'crowded' maybe.
Beautiful. The thing about the iQ versions is you can try different KT based tubes like the 150’s or 120’s and having had the non-iQ 200’s and now the iQ200’s, there is a substantial difference having perfect bias all the time. Substantial.
At the event last week we used the Select II into the VAC 200iQ monos and it was outstanding sound.
I’m fortune enough to have my store right near VAC (5 minutes) and spend time at the factory often. They are dedicated artisans that’s for sure.
The Statement Phonostage is my dream piece.
