dev
Banned
Dev,
I'm sorry I now realize how my post may have sounded. I am a dealer and I know they are amazing products. Bruce said they are very popular with Wilson and Focal. My room is just difficult for 2ch and I did not get great results with my gear and maybe it's my gear, not sure. Again I apologize , and glad to hear such positive results from everyone.
Hi DAV,
no problem and thx for clarification, opinions are just that. What works for one person isn't a guarantee to be so for the next which is okay.
How ironic when you know I don't know you or have seen your room but just from reading your comments figured it out quickly, home theatre set-up. Ya that's a pita, my opinion is the those two rooms sound qualities should totally sound different and if you have either of the two others sound wise mentioned those need to be sort out also.
Adding these StillPoints aren't going to correct a bad room, bad room usually means bad results no matter what you do as you have mentioned you just don't know.
I like being in a room that when talking human voices sound normal and natural, no clap echo, not over damped pretty well sums it up.
I have no financial ties so doesn't effect me.
My speakers are as per my opening info MBL 101E's which are a totally different design say from the other two you mentioned.
