I really can't see why would be an issue but certainly Lew could definitively answer your question. I can even email Lew if you need.
Sure.
This seems like eons ago, Kev!
I went to San Benedento Italy to listen to a pair of Strads at audio plus. Ended up coming home with a pair of Ktemas instead. With that said, the strads were a close second.
Myles - do you think a 35 foot SE run is a bad idea for CJ Art Monos?
Mike,
I see a vision of XS Pre/XS150 on one side of your upstairs room and GAT/ART on the other side.
Ken
Mike,
It will depend a lot on cable type and mainly on the preamplifier, not on the power amplifier. A GAT could probably easily drive many 35 feet long cables - I know about someone using a 30 feet Transparent Audio Reference MM2 - but I would be more careful with the ART S3, as it has much higher output impedance. For long runs we must avoid some ultra high capacitance cable brands. Both Cardas and Kimber have low capacitance IC cables, suited for long cables.
OR ARC REF250's with some sweet KT150's....or wait for ARC GS250's (we know they are coming) OR VTL 185 III's OR Pathos Adrenalin OR McIntosh 2301's.
Thoughts?
Thoughts?
uh oh. Those sure are pretty!
I also thought about BAT too.
Curious about Air Tight, Aesthetix, Triode Corp, etc.
[/URL[URL=http://s1096.photobucket.com/user/_bzr_/media/WestonArtisan300B_zpsce068e0d.jpg.html]
[/URL[URL=http://s1096.photobucket.com/user/_bzr_/media/WestonArtisan300B2_zps87e701d4.jpg.html]
