UltraFast69
Ed, Have you considered running Fiber the 45' between your switches instead of coax? I've replaced my 100' of ethernet with Fiber between two Startech fmc's. I may try the Sonore Optical Module fmc's instead of the Startech also.
I was thinking about that, but we recently did a complete overhaul to the power foundation - it is off the charts good, no joke (will post this).
So with that I pulled the dedicated circuit from the original sub panel and added it to the new panel and relocated the digital foundation (mode, etherREGEN, LPS and ADD POWR pieces 45’ closer but still in the other room.
Instantly you could hear things more open, dynamic and amazing sense of presence. After 6 hours I shut things down, paused 4/5 hours and just started up the system.
I have given up saying things can’t get better, this is off the charts after 30 minutes.
The AQVox SE has been pulled from 2 channel duty, and repurposed into home. I simply reversed the no longer needed Ghent 45’ Belkin cable coming out etherREGEN to the AQVox SE.
All these changes by better reconfigurement I ended up with another Audioquest Vodka Ethernet, Stillpoints Ultra SS, and a Ghent DC Oyaide Cable proving less is more - but in all fairness I had a head start with the addition of the panel.
