brad225
Do you have coaxial cable coming in to you home? Can you get that directly into your audio equipment location.
If so, look at an ActionTec ECB2500C Bonded MoCA 2.0 Coax to Ethernet adapter.
I only had coax that runs directly from the LNT box on the outside of the house. I really didn't want to convert the signal in the Frontier Router and run the signal via ethernet to my room.
The ActionTec is connected to a modified NetGear network switch that is local to my music room equipment.
This is not to say that when I use my iPad to control my music the router is not involved with the task. Just a direct connection between storage and player exists through the local switch.
If I didn't understand your issue, sorry.
