Hi Rex,
You’re not the only one who has optimized their network. I have an optical isolating ethernet filter that eliminates 99.99999% of noise on the line and has an upgraded audiophile power supply. It sits just before my Select II DAC. My network also has audiophile Cat 8 ethernet cables. The results are astounding. Music emerges from a dead silent background. The Roon Nucleus Plus in conjunction with the MSB Renderer Input Module leaves nothing on the table performance wise that I can hear.
Ken
I find it all makes a difference. Nothing in audio IMO is drop on the table and go. It all requires though, testing and tuning. If I had MSB Select II money I would try feeding it a superior signal from a purpose built device designed to only send the most clean ethernet signal possible. .......
From a performance perspective, no. When the network has been optimized, the Select II DAC played through the Renderer Input Module sounds significantly better than when I played discs on my Esoteric Grandioso K1/G1.
It would be interesting if you tried an Innuous Statement server and used it via ethernet vs. your Roon Nucleus. I have to imagine the robust power supply would indeed make a difference.
This corresponds with my own experience. Ethernet through an optimized network has always exceeded the performance of a disc spinner in my systems.
Oh, that comes as a surprise. That swings my thinking towards D1X instead of P1X. My PS Audio disc spinner did sound better than my music server, which had me leaning towards P1X until you said what you just said.
For MSB, having listened to both, I would agree with Mike that their Renderer Input Module and Select and Reference Transports, which are mechanically identical, are equal in performance. MSB’s Transports use a proprietary optical connection that surpasses in sound quality every other Transport I’ve ever listened to, in my opinion.
And as a side note, I wasn’t demeaning the performance of the the Esoteric Grandioso K1/G1 in my earlier post. It is a tremendously great sounding combo. My comments were directly comparing it to the Select II DAC plus Renderer Input Module only.
Best,
Ken
Ken, did you get a chance to try the cat6 vs Cat8 alone. I did as such with Cat5 and Cat6. There was a notible improvement. I am wondering if I need to dump my Cat6 and upgrade. I hope Cat8 will work with the Belden connector tool. If you say the sound is notibly improved I will dig deeper.Hi Rex,
Ken
Hi Keith,
I realize that some Innuous Statement owners would understandably be interested in this comparison, but no offense, I honestly am not. Unlike many audiophiles, when I strike oil, I stop drilling.
Best,
Ken
How much is the optical isolator influencing the sound? Was that a big part of the uptick you hear with the Cat 8. Did you get the optical isolator because the Cat8 is shielded all the way through creating ground loops?
I was using two Cat 6 cables with the EMO medical filter (I liked it better in my system than the fully tricked out optical isolation set up with special LPS). I then switched to the WireWorld Platinum Cat 8 cables with said EMO....It was a large difference. Everything was better, not just different.
EMO Systems is the site. I got this one: [FONT=Helvetica Neue, Helvetica, Roboto, Arial, sans-serif]EN-70e. I have found that not all optical filters make the system sound better. They all change the sound. All seem to lower the noise floor, but I have heard a friends system that is well over 150k total sound terrible. The lowered noise floor opened up the can of worms on how poor things sounded together. It was eye opening as even he heard it and was very upset as you can imagine. He know what had just happened. The last veil was opened up. He don't do analog so he never [/FONT][FONT=Helvetica Neue, Helvetica, Roboto, Arial, sans-serif]heard this. [/FONT]
