From what I understand, the 3502P is the replacement for the JD502P, which is a power amp only model (no preamp section, faceplate knobs, etc). I confirmed this with Jolida of Maryland.
The 3502S model is the integrated unit based on the same power amp design, in a steel chassis (thus the "S").
Then there is another 3502 integrated model, same as above, but uses an aluminum chassis, other upgraded parts and is more expensive.
And all the above models can come from the factory with 34 or 6550 tubes.
I had links to give you but not enough posts yet. Check out "petery-hedden.com/jolida-amplifiers/fusion-amplifiers/" website for more info. And search Jolida Fusion on Amazon, to get an idea of prices.
