Does the amp have XLR/Balanced inputs? If not....I'm screwed....
RCA only. You'll need adapters.
As I first turned on my new JOB225 to let it warm up, my first thought was "what in the hell is in this thing?" The amp is small and light. Is it Class D? Did I missing something in the literature? Amps this small shouldn't be producing this kind of bass from the first note. 60 minutes later.....time for a serious listen.
First impressions - the 125 watts is underrated. Comparing it to my 145 watt Marantz, the Job plays louder. The JOB225 has the bass slam
of a much bigger amp. Midrange presentation is forward (in a good way). Highs are rolled off nicely.
The biggest strength of the amp is its tube like midrange presentation and bass control.
On the downside, the JOB225 isn't the last word in tonality. The drum beat on the opening of "I don't care anymore" by Phil Collins (24/192 high res download from HDTRACKS) for example sounded less like drums than other amps. Like the sound from an expensive drum set compared to a junior one. The pro drum set will have much fuller, rounder sound.
On "Take it Easy" from the same high res box set, the acoustic guitar strumming didn't sound as rich and full as with other amps.
One big caveat to my criticisms above, the only RCA cables I own are of the BestBuy variety. I'm certain a better pair of line level cables would improve tonality.
At the end of the day, the JOB225 hits much higher than its weight category. This is an amp that could easily give amps costing a lot more - a run for their money. Power, slam, great midrange presentation and smooth highs....for $1695....its one of those rare high end bargains. Highly recommended.
P.S. Big thanks to Joe and Norman for turning me on to this great amp. I hope JOB gives you guys an amp for all your efforts....they probably sold half of their last run because of you two guys!
I think the new amp runs a little cooler the original amp. Not sure why. I think they sound very close if not the same. I need more time to compare.
Not just any Ice Cubes, but Ice Cubes made out of pure Mineral Water...so it does not pollute the soundIt runs cooler because they added two ice cubes in each amplifier![]()
Haha I thought Joe and Norman worked for Job??[\QUOTE]P.S. Big thanks to Joe and Norman for turning me on to this great amp. I hope JOB gives you guys an amp for all your efforts....they probably sold half of their last run because of you two guys!
