NorthStar
But AJ, CD has a brick wall in the high frequencies that affects the midrange with harmonic distortion.
No Bob, not in reality. Elsewhere, sure.But AJ, CD has a brick wall in the high frequencies that affects the midrange with harmonic distortion.
Bob, do you actually read the links you post? None of these articles have anything to do with the discussion here, and almost nothing to do with how CD's can sound (absent the dynamic compression from the loudness wars, and the often deleterious effects of other DSP)
Once again, either irrelevant (the first) or wishful thinking (i.e., no actual scientific or engineering information, just an uninformed opinion) in the second.I do read them, and I like to go beyond. But you don't have to read them, you're free.
• https://www.emusician.com/gear/brickwall-limiting
• http://www.indiana.edu/~emusic/etext/digital_audio/chapter5_rate.shtml
The compact disc is flawed; the frequency response should be extended from twice the 44.1khz to 88.2khz. ...And the bit rate from 16 to 20 bits.
Yes.Rob, do you take the time to read the articles?
History: https://www.philips.com/a-w/research/technologies/cd/beginning.html
There is a pdf link @ the very end, by clicking on the very last word.
____
• https://cardinalpeak.com/blog/why-do-cds-use-a-sampling-rate-of-44-1-khz/
Bob Stuart from MLP Meridian wrote an article years ago saying that we need 88.2 kHz and 20-bit rate for hitting the plateau of true high fidelity in audio. DVD-Audio reached that.
Stereophile has measurements from graphs showing the abrupt brick wall of CDs @ 22 kHz with harmonics of different orders impeding in the lower frequencies of the sensitive human hearing, the mid-range from 1 to 8 kHz.
Is CD lossless or lossy? It is uncompressed and flawed. The words lossy and lossless have to be interpreted in their right context, and the results.
Today we have compression algorithms that are more efficient than in the past; like in photography, moving pictures, multichannel audio soundtracks.
And your point is?Even the professionals can change their mind, and have different opinion among them.
Some of the greatest scientists didn't agree with the top scientists.
Hundred years from now all this ultra high end audio reproducing gear and hi res audio files will sound prehistoric and so far off from the real tones of musical instruments.
Music is bliss. The less lossy the better.![]()
The most sensible comment on this entire thread!
Do we have a consensus Btw - would have thought this is a yes or no answer.
There will never be consensus on any audio related topic on any audio forum.
I may be wrong, but I think the consensus (with possible dissent from Soundfield Loudspeakers) is that all recording media is lossy to some extent, one has to go with whatever sounds best, which is also probably the least lossy....Do we have a consensus Btw - would have thought this is a yes or no answer.
