Is CD lossless or lossy?
Received this newsletter this am - another perspective:
"Taming the Terminology: Lossy vs. Lossless
Dr. AIX
Can a PCM digital audio file at any sampling rate and word length ever level be considered "lossy"? Despite a recent article on a popular audiophile website, the answer is an unambiguous NO...never! By definition Pulse Code Modulation is a lossless digital encoding scheme that preserves 100% of the original signal given the right filtering and parameters. How the simplest terms can get twisted and recast by casual — and uninformed audio writers — is not really surprising but problematic for readers looking for accurate information. Let's briefly take a look at these terms and explore the underlying fallacy put forth in the piece.
The terms lossy and lossless ONLY apply to compressed audio formats like MP3, AAC, AC3, and MQA. Lossy means that some of the source audio information is lost — forever — when the compressed digital audio information in the file is converted back into an analog signal. If the process doesn't restore 100% of the original signal — which a properly designed PCM digital encode can do — then it is considered "lossy". It really doesn't matter if listeners can detect that there is information missing. I'll grant you that it can be very difficult to perceive the difference between a lossy algorithm and a lossless one. In fact, some listeners may prefer an encoding technique that "masks" some low amplitude signal or "folds" ultrasonic partials under the "in band" information. However, one's subjective preference doesn't change the technical reality.
A truly lossless audio format like MLP (Meridian Lossless Packing by the same folks that are behind MQA) — now known as Dolby TrueHD due to a licensing arrangement with the SF-based company — guarantees that every single digital bit of information that was present at the input of the encoder is present at the output of the decoder. When the DVD Forum was casting around for a scheme to reduce the bandwidth needed for 6 channels of 96 kHz/24-bit (high-resolution surround sound) on a single speed DVD disc, the very bright people at Meridian accepted the challenge, demonstrated their amazing process, and were awarded the exclusive contract for the DVD-Audio format. MLP, Dolby THD, FLAC, FLAC, DTS HD Master Audio and a few other codecs have demonstrated their ability to restore the bits from the source to the destination.
One of the examples discussed in the article focused on the fact that many — if not most — new recordings are being done using sample rates and word lengths higher than 44.1 / 16-bits. In fact, iTunes requires that labels submit their digital masters at 96/24. If the engineer at the studio captures the sessions at 48 kHz/24-bits and then downconverts those recordings to 44.1 kHz/16-bits, "then the CD version would thus in effect be lossy". Wrong! The downsampled CD version would still be lossless because as I pointed out above, there is no such thing as "lossy" PCM. The Redbook specification for compact discs doesn't include a chapter on data compression or codecs.
The process of downconverting or downsampling can be done a number of different ways. Usually, a software program does the conversion in real time or out of real time depending on the complexity of the algorithm. It's possible to downconvert from a higher sample rate and longer words during an analog transfer. The output of a DAC is passed to the input of an ADC running with a slower clock. However, in all of these processes the end result is still lossless.
The confusion may lie in the notion that there is a difference between the original master and the final CD specification audio. If a 96 kHz/24-bit PCM master is "mastered" for CD release, some of the data of the original recording will not make it onto the final CD. That's a fact. But that still doesn't mean that we should call the CD a lossy format. But it gets even more confusing when you understand why recording engineers use higher sample rates of longer words in the first place. I've written about this before. There is increased "headroom" available at the time of the original recording offered by the additional 8-bits. Recording engineers don't want to exceed the available headroom of their recording system. We had limits during the analog tape days and we still have limits today — thankfully high-resolution has brought great potential fidelity. However, mastering engineers have a different task than the recording and mixing engineers. Their job is to adjust the tonal balances, reduce the dynamic range, and increase the amplitude of the overall track. The reduction of dynamic range and increase of amplitude takes the original 24-bits down to 8-10 bits — remember that each digital bit is roughly equivalent to 6 dB of dynamic range.
So even the master won't be different when downconverted from 24-bits to 16-bits because the mastering engineers already knocked off the extra 8-bits. That's just the way it is for most commercial releases — including jazz and classical titles.
CD are not lossy. There should never have been any doubt."
I 100% cannot disagree with AIX.
I don't grasp the logic of that argument, except in the sense that PCM audio is defined as lossless. Because really, what is the difference if information is lost by resampling and dithering or by a predefined psychoacoustic algorithm?
Having made hundreds of master tapes, and having heard many more, for me the only lossy format is vinyl, since it is a poor comparison to the master tape - it’s not even close.
Not to mention the effects of wear with each playing...[emoji856]
As usual, IMO... 🤭
