still-one
I decided to give one a try and contacted Mike to send me a GigaFoil v4 and a AQ Diamond ethernet cable.  Like the song says I am hoping the result is "you don't know what you got 'till its gone".
I have several Teddy Pardo PSUs. They are good.
Other linear PSUs worth checking out:
https://www.mojo-audio.com/illuminati-v3-power-supply/
https://uptoneaudio.com/
http://www.paulhynesdesign.com/ (some say those are the best; be prepared to wait for weeks to get yours though!)
ifi Power is a great budget PSU.
Ed, I believe best practice for optical isolation is last connection before the DAC. That way nothing inserts pollution after it.
Can someone start a list of all of the recommended digital dingleberries you need to make your system really shine? And digital dingleberries are anything you insert in the digital signal path that is not required to hear music play.
Jim, thank you. I’m also investigating some possible power supplies for it as well. It may take some time.
Looking at:
http://www.kecesaudio.com
http://www.paulhynesdesign.com/page7.html
...among others....
I read the review from the link you posted. I thought the PS that comes with the filter is a linear PS. If so, what’s the problem with the PS that comes with the filter?
Or just for the sake of streaming only you can just buy a Lumin X1 and not worry about all the added parts.
True, but even the Lumin benefits from either an fiber optic setup (it now has fiber inputs) or a GigaFoil. I have only compared the X1 and MSB with the GigaFoil and Fiber setup and prefer both the GigaFoil going Ethernet to Ethernet. I found the fiber more tipped up, whereas the GigaFoil just sounds “cleaned up.”
Whats the real net gain. Jumps out and grabs you, very noticeable, noticeable, subtle or takes work to hear it but valued as a final dusting to make it all perfect.
I'm interested but I would like to hear from some people who own the Aquavox or Linear Solution switch who add this and what do they hear. I already have low noise and femto clocking switch. I could also use my money ($1600) and get an endpoint to increase my performance.
Just trying to figure where my money is best spent.
I agree with Mike. The GigaFoilv4 Filter removes all the noise but changes nothing else. There are no downsides. It is an amazing product!
Ken
