Mike, thanks for sharing your thoughts and your new R2R. I'm sure you are going to get a lot of enjoyment from the equipment.
One point, remember that the Opus 3 Samplers are not direct dubs from the master tapes. They had to create a sub master with all the excerpts from the different albums. I have the first three sampler albums and they are both a good cross section of the Opus 3 tape catalogue and at a very reasonable price. But the jewels are the direct dubs. I bought 10 of them (with a little discount from Kevin) and they are spectacularly good. They are not cheap, much like the price of the Jacintha Here's to Ben tapes. But they also contain a full album of music - 45 to 60 minutes worth, and come in 2 tapes. So its like $250 per tape. To preserve the original masters, they are limiting the number of copies to 50 - so, like 'Here's to Ben' there won't be any more direct dubs. BTW, I tried to get 'Here's to Ben' and couldn't. :-( Ended up with Jacintha's 'Autumn Leaves' - spectacular.
I think I was one of the earlier people to get a reworked machine with new electronics (a reworked Technics 1506 that Bottlehead provided with their Prepro - and a wireless remote!) about 5 years ago. It wasn't cheap then, but not like the current stuff. The newer electronics may be better, but I have been quite happy with the Bottlehead prepro, especially using its balanced outputs.
I got the machine specifically to play the then new Tape Project tapes. Since then we have a steady (or not so steady) stream of additional sources - Opus 3, Ed Pong's UltraAnalogue, Bob Attiyeh's Yarlung, Jonathan Horwich's IPI, Volker Lange 's Lutz Precision and others.
I would urge those of you with R2R tape players with NAB and CCIR EQ to try these out. I just counted and I have 85 of these albums, many of them with 2 reels. They are not cheap, but will give you a sense of reality and musicality that I don't find from any other source. It will also support a noble cause.
Unfortunately, almost no one is recording in R2R. Even people like Keith Johnson no longer do R2R backups of their digital recordings. As my Decca engineer friends told me, editing with a razor blade is a PITA. John Dunkerley says he can still hear every edit he did on this many analogue recordings.
Larry
