It's just you Steve......LOL
What speakers are you using & is there a SAM profile for it ? I have a D200 and to be honest , I haven't had any such issues . Are you utilizing the analog inputs ? Many on AS feel they are inferior to the digital inputs or using the Air streamer.
Shodhan
For the same money as the Devialet, I can build a system that will leave it in the dust.
As I've said before, its a great piece IF you agree to live within the Devialet ecosystem and IF your speakers are not terribly demanding and IF you don't worry about obsolesces in the DAC and IF your cables will plug into the back!
It a revolutionary piece and the SAM technology is brilliant...perhaps even game changing.
My biggest beef with ALL the Devialet units I had was that they all sputtered and hissed and cut out at 93db+ levels on various speakers.
Unlike some reviewers, rather than say every speaker is the greatest on the planet and every piece of gear is my next reference piece, I prefer to point out the good and the bad - even with my own personal gear. The Devialet is not perfect, but it is damn good if you're willing to accept its shortcomings mentioned above. I was not.
Largely agree with you, Mike. Love to hear good balanced critical appraisals of audio gear. Nothing is perfect.
Compromises have to be made. I have to run D200 without the back cover to fit my power cable. Yet to find an audiophile IEC plug that will fit under the cover. Bananas rather than spades suit the cramped quarters. Happy to compromise here as I love the slim profile and exquisite form factor.
BUT, those terribly demanding speakers that you refer to would surely challenge most amps out there. The D's have a reputation of being fairly load tolerant and able to drive most speakers. Of course, amps must be matched with suitable speakers.
The Devialet ecosystem is not such a bad place to live in.... UNLESS you want to incorporate something like a Lumin that already has it's own DAC. Maybe one day Lumin will introduce a DAC-less server, then Lumin owners wouldn't have to worry about obsolescences in the DAC
I run D200 with Magico S1 speakers. Moderately demanding speakers - they present an under 4 ohm impedance from around 6.5 KHz upwards dipping down to 3 ohm from 11 kHz upwards. No hissing or spluttering yet encountered. However, if I wanted to drive speakers that were significantly more demanding than S1's, I think that I would be considering dual mono D400.
garata,
Cardas IECs fit under the rear cover.
Audience uses them on their power cords.
The Furutech FI-15 plus IEC fits under the cover of the Devialet - that's what I use with their FP-Alpha 3 power cable
Another take on the Devialet verses separate components:
SoundStage! Ultra | SoundStageUltra.com (UltraAudio.com) | Devialet vs. Benchmark/Parasound/Pass Labs
BTW, according to their Facebook page, Devialet will be announcingsome new technology soon.
