Hey Mike,
Doesn't MBL also offer some class D amps?
My buddy from the audio club who has the same MBL speakers as you do and their big boy mono blocks and the MBL pre-amp had EJ build him mono blocks to use on the bass. He is thrilled with what the class D has done for the low end while using his MBL's for the rest.
As a side note, EJ modified the amps only to install special speaker terminals because the the cables that our friend is using are so huge that they could not attach securely to standard terminals
Wyred 4 Sound SX-1000R
I believe that Jim Smith has one of these and could probably give you some insight on it.
Wyred 4 Sound ST-750LE
Yes, but they are a hybrid of sorts.
“In a Class D amp the input is first converted/encoded by a modulator into a pulse train (using pulse width, pulse density, or related modulatory techniques) that represents the amplitude variations of the audio signal. This pulse train is then fed to the amplifying devices (usually MOSFETs), which operate like electronic on-off switches. Working alternately, these transistors switch back and forth between the supply rails, generating positive and negative boosted signals that are subsequently low-pass filtered (to get rid of the very high frequencies used by the modulator to encode the input signal), sometimes high-pass filtered (to reduce residual distortion), and fed as a higher-gain analog (sinusoidal) signal to the loudspeakers. Theoretically, a switching amplifier (which dissipates virtually no power as heat) has an efficiency of 100%, while Class B amps have a theoretical maximum efficiency of 78% and Class A amps 20–50%.
Unlike its predecessors and much of its current competition, the Noble Line N15 monoblocks under review are said to guarantee a linear signal independent of load, level, or frequency. This is a bold claim, considering (as MBL itself points out in its LASA 2.0 white paper) that Class D amplifiers inherently distort the music signal depending on frequency. (Natively they have low THD in the bass and very high THD in the treble.) Moreover, Class D amplifiers are always designed for a particular resistance value (e.g., 4 ohms), but a loudspeaker does not have a constant resistance—it is a “complex load” with impedances varying with frequency. Thus, in addition to their native non-homogeneous distortion profile, Class D amplifiers change their power delivery (and hence their frequency response) with changes in load. On top of this, the louder a typical Class D amp plays, the lower its overall distortion, and (paradoxically) the quieter it plays, the higher its distortion.
MBL claims to have solved these myriad problems with its LASA (Linear Analog Switching Amplifier) 2.0 technology, which, instead of the typical and economical switch-mode power supplies of most Class D amplifiers, uses a massive analog toroidal power supply. The LASA circuitry is also symmetrical in layout for better common mode rejection, employs low-drop fast-recovery rectifiers to create a low-noise supply voltage, and has a “soft-clipping” provision to eliminate aggressiveness and distortion at very high output levels. Whether or not these strategies result in an amp that (as MBL claims) is closer to Class A or Class AB in linearity, noise, and stability than it is to typical Class D, there is no question that the N15 differs sonically from the switching amplifiers I auditioned lo these many years ago.”
Source:
MBL Noble Line N11 Preamplifier and N15 Monoblock Amplifier | The Absolute Sound
