Kingsrule
- May 11, 2014
Brian,
You should suggest to Brian Zolner to re- think the way he protects the amplifier, as it is , it's really an 8 ohm drive amplifier, since most 8 ohm nominal speakers will sometimes see 4 ohm or below as z-min or via phase angles. A 4 ohm nominal loudspeaker could see z-min below 2 ohm for the same reasons. At this price point not being able to Drive a 2ohm load past 10-11 amps is a let down and i can see customers having issues with this if the amp should shut Down on them, not to mention it has been my experience , amplifiers which are over protected like this, tend to sound , well , polite and restricted. This could be what Fremer is alluding to.
Aside, the test measurements by JA, showed a well designed amp into 8/4 ohm , excellent as a matter of fact , not sure why Bricasti would chose to limit such an amplifier like this ...
Regards..
+1
Hey Brian, you having another melt down yet? LMAO!
