a.wayne
I telegraphed this guy after his email came up as undeliverable:
Crap , i thought Nyquist told you ....
You're welcome Al Read on:
No, but his Cold and Flu Nightime stuff is greatCrap , i thought Nyquist told you ....
Thanks for this detailed response and its pretty obvious your digital smokes your analog in your current setup , my only disagreement is you keep throwing in cost, your digital beats your analog not because of cost, as your analog budget is good enough to match or best your digital imo, more comparisons and a few merry go round purchases maybe necessary to get you sorted ..
just recently a friend brought over his new phonostage he was raving over to compare, its on ebay now.
Unfortunately this is how it is ..
Regards ,
Not being defensive with this question, just asking. What analog chain will give amazing results for $9K complete. Table, arm, cartridge, phono stage and cable. I will even give you $15K list since that is my digital list. I just usually try and find a show demo or a return for upgrade unit to save $. That is why I am out more around $9K. Thanks.
VPI Prime - $4k
Ortofon Cadenza Black - $2600
Manley Chinook - $2k
Furutech Phono Cables - $400
I think the reason Mike L can say some people may want the clarity and gravitate towards digital is because they have a system such as mine. Mike gets the clarity, dynamics etc with his vinyl setup. Its wonderful.
the MSB Select II and the other optimizations of my digital performance do break thru prior performance ceilings quite dramatically, and it does go places no previous digital has gone. and, I suppose, depending on one's sonic priorities, if someone valued 'clean' over content, then I can see where they might move digital equal or ahead of analog. but connection to the musical event is what analog does best.
What is the block in My vinyl? Phono stage? Allnic is suppose to be pretty good. Chinook has a lot of features, not sure it has more fidelity. Little brother to the Steelhead as is mine to the 5000 series. Cartridge is probably better. VPI is nice. I though you would say a Techniques Mark 2 or Lenco.
Of course, its all back to the give it a try and if it does not perform?????
If I want to expend more cash on Vinyl I would probably take Joe Pitman up on lacing a new single strand of high quality tone arm wire from the cartridge tags to the phono stage. I find removing connections always improves sonics.
Seems like I am an equal offender to both some vinyl and some digital aficionados on this thread. So be it. I am only interested in the sonic truth.
It was the post that apparently triggered this thread!BTW, I must have missed the paper on where 90% of the analog soundfield went ...
Not an exactly because u always qualify/reference/refer to the price as a consideration which in itself is OK but it's obvious that's a factor in your determination of a component's merit........
What is good digital , how do you know when you have it ..?
The folks claiming objective metrics like price = sound quality aren't using their ears.maybe my ears are not good enough to appreciate any higher....
