Damping factor specs: All measured at 1 kHz.
Vitus RI-100 - 20
D'Agostino Mono - 55
Classe M400 - 100
Soulution 501 - 4000
Soulution 710 - 5600, at 100Hz 6900 and 10kHz 12500
FMA 711 II - 400
Burmester 909/911 - 2750
Gryphon
Diablo - 380
Atilla - 55
Vitus RI-100 - 20
Classe M400 - 100
FMA 711 II - 400
Bravo output current - 44A peak, output voltage - 50V in 4 ohm.
Symphony output voltage - 40V in 4 ohm.
Slew rate - 38V up and 18V down.
Damping factor at 100Hz/1kHz/10kHz - 518/513/284
Gryphon
Diablo - 380
Atilla - 55
Pass Xs
Damping factor and output current peak
Xs 300 - 50 and 50A
Xs 150 - 50 and 30A
Accuphase A-46 - 67 in 4 ohm.
The A-46 brochure says 500, a big difference from the spec above which is from a review.
P-6100 - 445 in 4 ohm. (brochure - 500)
Damping factor - Damping factor
Thanks Mike, excellent post!
Gryphon
Diablo - 380
Atilla - 55
Ok, but the part I was waiting for was what would be the ideal damping factor number & why?
Why not keep the REF10 for Pre and choose SS amps of choice.
I would love to! But, tubes anywhere in the chain (except phono stage!) - I found to be less than ideal for the Raidho's.
Mike...from a technical standpoint, tubes in the pre should not mean less woofer control and woolly bass in the D3s. All the pre is doing is outputting a small 2V signal to the amps which is where all the work is done to apply another stage of gain and amplification and driving the speakers. I am not questioning what you are hearing but my guess is there was probably a mismatch between the Ref 10 and the SS amps you used than the issue being tubes in the chain in the preamp stage. In any case, I generally think it's better to keep pre and amp matched from same manufacturer anyway, so I am not trying to dissuade you from selling the Ref 10 but just trying to point out that you're not liking the Ref 10 with the SS amps you tried on the D3s probably has less to do with tubes in the Ref 10 and more likely a mismatch (impedance and otherwise) with the SS amps you tried. Just my 2c and speculation on the subject.
By the way, are the D3s displacing the Aidas in the big rig or are they going into the family room?
From Raidho website
Amplification > 50 W (Though we have seen excellent results with small tube amplifiers)
I wonder what tube amplication are they using
A high damping factor isn't the only spec one should looking for when selecting an amplifier.
Also look for high slew rate and high output current.
High rise and fall slew rate means a very fast amp with very good control of the drivers on a speaker.
Not too high like Spectral with a 650V slew rate - not uses a filter at the output, means it need a filter inside the speaker cable, if not use cables with a built in filter the amp will oscillate/blow.
Amps with low output impedance, for example Boulder 2050 and Gryphon Mephisto - both have 0,02 ohm output impedance.
2050 is using feedback, Gryphon say they have Zero global feedback, but they are using local feedback with that low output impedance spec.
True zero feedback amps have higher output impedance - around 0,2 ohm and higher, many of them still have outstanding bass and control even with a damping factor of only 15.
Actually one of the best amps I've heard with a outstanding bass and control have a slew rate of 60V, 100A output current, 0,33 ohms output impedance and a damping factor of 25.
Thanks Wizard!! What amp was that?
Yes I forgot to write the name of the amps - it's AM Audio Excellence.
