Bill, Just to add to your decisions, I swapped out the "AMG" private labelled (Cardas) cable for a Steath Hyperphono. Highly recommend it, though you may find shindo synergy with the rest of your shindo system.I want to upgrade the phono cable on my table to the AMG Reference like yours, the Siltech that Kev mentioned, or I just found out that Shindo will make one for me at a very reasonable price. The basic AMG cable sounds great, but that particular cable is bound to be the most important in the entire chain. Decisions decisions...
Oh, but which lp to christen this beauty? :doubtful:My AMG V12 was delivered today by dealer/Shark Mark Jones. I'm just getting started listening and it is such an incredible upgrade that I am just stunned. I'm using the AMG reference tone-arm cable and the AMG Teatro cartridge. Below is a photo of the V12 sitting on my Rix Rax audio rack with the Diapasons in the background. I'm full of joy!
Bill,Thank you tunes... Was it the basic level cable or the "reference" AMG cable that you left? Also, thanks for letting me know they use the Cardas line. Maybe I can glean some information on their phono cable levels. I know the Shindo would be silver. And very reasonably priced as cables go...
I have been following this thread with a lot of enthusiasm because some time down the line I plan to add a AMG Viela to my system too. I currently use Verdier Nouvelle Platine and Jean Nantais Reference Lenco MK2 turntables. I have been also trying various cartridges in the last 2 years. My cartridge search ended with a surprisingly lower priced Audio Technica ART9. Prior to the ART9 I had tried the Benz Ebony TR, Lyra Skala and Miyabi 47. The ART9 superceded all of them convincingly for a price thats quite shockingly low. Well, the ART9 is the flagship of Audio Technica so it should be good but then in audio as we all know price and performance cannot be way too off. I strongly suggest you guys give the ART9 a try. It is not expensive but its neutrality, speed, dynamics and timbral accuracy is up there with every $5k cartridge I have heard as yet and even more it is more accurate than most.
Has anyone tried different tonearms on the AMG v12? I am considering getting the upgrade “AMG Turbo” arm, but curious if anyone has mounted a Kuzma 4point or other highly respected arm? (Is possible?)
If so, what were your impressions? Did you compare to the Turbo arm?
It's possible, but I'm not convinced it would make much sense. Sure, tonearms do matter, but the AMG Turbo is such a high level arm which is also very easy to optimize and fine tune (on the fly) that replacing it for the rather clumsy 4point does not really make sense to me. I would rather try a variety of cartridges to find the one for you combined with optimizing the rest of the analog chain including the phono stage and the sensitive cabling involved.
/ Marcus, www.perfect-sense.se (representing AMG in Sweden/Scandinavia)
I have to say, your comments indeed are “perfect sense.” And with trade in/up from the standard 12” arm probably the most economical choice. I haven’t seen comments here or elsewhere of people who upgraded to the turbo arm...
