a.wayne
Imagine the discourse when You actually get your hands on hi rez top Tier Digital playback
As I explained, the differences in dynamics were so huge that they simply cannot be explained by differences in system dynamics, and that the other system also can sound very dynamic. And I have heard other orchestral LPs on that system with a much wider dynamic range. I used this example because it particularly highlighted the issue, as I explained in my post:
So no, the LP/CD comparison does not always yield this result. This was a particularly drastic example that I used to try to explain an artifact which to a much lesser degree may very well also be present on other LPs of 'big' orchestral music, and which would explain the extra 'detail' and 'fullness' heard on LP.
Just like other music, orchestral music can sound dynamically explosive on LP, but then mostly on 45 rpm pressings. For example the Reference Recordings Symphonie Fantastique is incredibly, stunningly dynamic on great vinyl playback. But it still does not have the huge absolute dynamic range of that Mahler 3 recording. If you would try to put that dynamic range on LP, the soft passages would probably compete with some surface noise.
It is also no coincidence that the Sheffield drum track is on a 45 rpm LP, on one side of only 7 minutes length. You could not get those incredible dynamics from LP on a 33 rpm pressing of 20 minutes length with much less wide groves.
You could, however, easily get such dynamics on a standard CD, as for example can be heard on the famous 7 minute drum solo "Freedom Rider" by Art Blakey, on a CD of more than 70 minutes length (Complete Blue Note Recordings, volume 1960-62, CD 3 of 4 CD box set).
"If the former, I could possibly understand. If it's the later, I have observed different outcomes that depends on a few variables. Experience tells me it is usually up to the process of how the track was transferred to the medium(s)."
Of course not. Who wants to be exposed and look silly for the entire world to see? It will never happen for that reason. Most audiophiles have just enough sense/cognizance to evade these type things.AJ, have you captured a Youtube of your ADA test yet. I gather you never got Al to your place. The other thread just ends.
No, you're not wrong to say that within the limits of your stereo, you prefer X vs Y. That is not contentious whatsoever, nor anything to discuss further. Preference is absolute.I guess its wrong to say one betters the other because something can be changed to alter the outcome.
The event that AJ referenced above was on May 22, 2016. I found my notes from the event! The owner of Pure Vinyl did a presentation to the audiophile groups in Tampa and Sarasota at Bart’s house. At the time, Bart had JAMO speakers and Pass electronics, combined with EMM DAC. The Pure Vinyl guy brought a modest Rega turntable. My notes indicates a KORG A2D was used.
Using Bart’s large screen and projector, he was able to project the results from his laptop onto the screen for everyone to see and obviously, hear in real time as the record was playing and the analog was being captured and converted to digital and then played back and compared and contrasted at the same time to the record being played.
A first Japanese Pressing of Pink Floyd’s DSOTM was used as the source. An all analog recording and pressing at the time.
What the test showed, was that even at the highest sample rate (24/192 in this case), there was still quite a bit of information on the record that was not being converted to digital. It was being truncated. Moreover, it was clear to me and everyone there (AJ may disagree, but at the time, pictures of his face show otherwise!) that the vinyl was clearly superior sonically and the data didn’t lie. There was information on the record that could not be captured by the Pure Vinyl. At the time, 24/192 was the highest level we could imagine. Would that change with a much higher bit/sample rate? I don’t know.
Prior to the experiment, the digital only guys argued that we couldn’t hear above 16/44, but what the test showed and my notes clearly indicate was that there were indeed sonic cues, air, ambience and more that was being truncated by the digital file even at it’s highest sampling rate.
I think it could be argued that in 2016, software, ADC’s and the like might not have been at the level they are today and the results today might be different, especially with higher sample rates.
But in the end, this very old technology of a needle in a groove still produces fabulous sound and fun for millions of people around the world.
I think you have added more information for those reading.
However, it still appears you have added support to my comment you replied to:
On a final note: If you want to know my general thoughts on the original question posed by Mike, you can see it earlier in the thread here: https://www.audioshark.org/showthread.php?t=16741&p=276766&viewfull=1#post276766
No Mike, the real time ADA level matched switching was maybe 2 years back, held at a Hillsborough County library. I do recall that event at Barts, that was vinyl ripping. That Channel D (?) is pretty neat software.The event that AJ referenced above was on May 22, 2016.
My event, there is no recording, its all live LP playback, straight vs a ADA looped version
We should get back on topic rather than another analog Vs digital.
One topic is logically linked to the other, Mike. That became even more clear to me as I just re-read your OP.
The answer to your question "Why no turntable" is intrinsically linked to if you find it sonically necessary or not.
I very much enjoy vinyl in my friends' systems, and often really love the experience. But I don't find it necessary for myself. Even though there are some occasions where the same recording really sounds better on vinyl than on digital.
You need a turntable in YOUR system to really experience it. Otherwise, it’s a mute point. Listening at friends homes just isn’t the same. Not even close.
I agree, no one NEEDS more than one source. Its suppose to be about enjoying music. Not analyzing your system. It's just a choose to have a second source. Or third. I made the mistake of buying a third source. Huge waste if money and a letdown for me. No desire to dump gobbs of money to try and make it better. The only good a 3rd source did for me was show me the cost of media for the first two is very affordable. Especially the streaming. As far as vinyl, digital and vinyl are close enough sonically it appears a waste of money, to me, to but high end records. The beauty in vinyl for me is finding an old Ray Charles or Art Pepper for $6 and its a smoking good recording. Spending $50 to get a remake that takes a concerted A/B to discern the differences between vinyl and digital is not a good use of money. For me.
Edit to add, When I say vinyl is better than digital, the old Ray Charles, Art Pepper, Duke Ellington, Ella etc are the amazing finds on vinyl that digital reissues miss the magic. I have some $6 to $19 old records that are just amazing. The remakes of these album are not like the old vinyl. There is tonal purity in those grooves. And they are affordable.
Why watch golf. Buy a Golden Tee golf machine.
