Thanks. I will start one later. The sound is intoxicating. The Raidho sound keeps you wanting more and more and more. I couldn't be happier.Wow! What a beauty! They should go well with classe don't you think? How are they sounding so far? Was there a separate thread for the riadho?
Mike. We have one here in Toronto...Sorry.
Mike,
You need to hear D'Agostino on those D1's. Mark will give you his opinion next week but I suspect you may be overlooking the obvious.
Beautiful speakers, Congratulations!
Mike...congrats! Are you finding the Classe - Raidho combo a bit lean? I am guessing that is the case because with your exploration of Vitus it sounds like you are seeking maybe a warmer/fuller/meatier sound in SS land, which Vitus may deliver. What did John of Audio Salon drive them with (was it Constellation)? If you want a reasonably priced but still excellent SS integrated, check out the Hegel integrateds. Going up from there, Vitus and Gryphon are voiced in Class A bias and will deliver a meatier/fuller sound. Just some suggestions to look into. I know you mentioned Simaudio in another thread, and they put out excellent sounding gear but it is very neutral and some will find it a bit lean sounding so not sure about the combo with Raidho but also worth an audition.
Good luck.
Mike,
Take Joe's advice.It sounds like a good match.
Mike, are you using the Tara Labs the One one the Classe? If not, give that a try. They tend to enrichen the midrange on down, giving a tad bit more body and weight to the images. There may be a sacrifice of top end air, but worth a try IMO.
The best I've heard the Raidho's were with warm components. A class D amp did not float my boat with the Raidhos; Dartz integrated complimented the Raidho's huge soundstage to perfection, with a touch of warmth to the images. I think the best sound I heard from the Raidho's was with Hegel gear driving them: warm, full bodied, albeit a loss of soundstage, but could have been the room/setup (and at a show). Like others, I would think the Dag and Raidho combo would be TDF though!!!!:exciting::audiophile:
Try the Tara Labs PC to start. I am auditioning a pair now and it has definitely richened the midrange and bass!
Good luck, Mike! Let us know how it goes!!
I think you should go with the following:
1 ref10
2 ref250
1 ref2se
1 refDaccd9
That's my 2 cents
Hahahahhah
I'm so humble
Hahahahhah
