Guys, I'm sorry but reading the info from the Roon website is like trying to read Russian without studying the language. The technical jargon immediately confounds and loses me. They assume you are either an IT guy or you have a PhD in computer engineering. I need this to be as simple as possible.
nicoff, to answer your questions...1. My computer IS connected to the Nucleus via USB.
2. Yes, there is a folder that contains all my music files. It's on the File Explorer page. None of my files show up on Nucleus (my iPad) thus far. Just to clarify, my music files are on my PC (File Explorer) and external HD.
On my iPad, I've gone to Roon Settings, then Storage. When I navigate to the "Storage" page under "Storage" it says..."Folders."
Under "Folders" it states..."Roon will monitor folders for new music. Your files are left in the folder and won't be copied or modified in any way, unless you explicitly choose to add or delete them from your library." Off to the right it says..."+ Add folder"
That's all it says on the "Storage" page. There are no files or anything else.
Do I tap + Add folder? When I tap "Add folder" a window appears the says "Choose music folder." What folder? There is no folder to choose.
At the bottom of that page it asks "Add network share... Then it wants Network share location...User name...Password...then Workgroup. Then at the bottom right
Then at the bottom right it says "Cancel" and "Select this folder." But there are no folders to select and there is nothing else on this window.
