dev
Banned
Any owners care to share their experiences, I see pics of them being used in numerous set-ups at shows.
I have used numerous manufactures product over the years and as the norm will be system dependant.
What I like about the product is the cables are flexible, the fit and finish is top quality and obviously what they offer.
Serguei seems to be continuing to learn and producing new product - one can clearly hear the differences also.
I have been using the product for numerous years now with satisfaction, one recommendation I would to suggest is not to mix and match cable manufactures, I have found synergy occurs when you utilize product from the same.
I use balanced IC's "interconnects" between amp and pre and all other components to pre-amp, my speakers are designed to be bi-amped or bi-wired. I have two runs of Dream cables to each speaker. I also use all their power cords to creat a Star grounding configuration. If you aren't familiar check out their site for explanation.
I have made some changes over the years - I started with using the Indra's for IC's but moved up to the Sakra's - I was also using the Sextet between Dac and transport, I tried both AES and RCA terminated version and preferred the AES.
I knew they were working on some new flagship speaker cables called Royale's, at first seeing them side by side in a pic my initial impressions was wholly crap these are huge.
My concern was to have true bi-wire, due to the new design not a concern so I no longer need two runs - just have one end configured to bi-wire which I had done.
Next was my Sakra's had a new update called V12 - any technical best you go to Stealth site.
I have been very happy that I have been able to trade up and not take a huge beating to the point it made no sense to sell myself so that's nice.
I know there allot of individuals who believe cables don't do anything but that's not my take and can easily demonstrate to the point that there's no need for one to concentrate because it's so obvious.
Not looking at getting into any debates but to share exsperiences.
