Speaker placement
Thanks!
Always a pleasure to look at your room and your system :thumbsup:
You might want to check your toe in angles with your laser. So I see the submarine above your TV. Were you in the Navy and a submariner?
It’s the picture, it measures proper.
Yes, I navigated nuc boats during the beginning of the end of the Cold War - fun times
Beautiful setup and room. Check toe in. I’m sure it’s just the picture, but the right speaker looks more toed in than the left. Again, probably just the angle of the camera.
Yes, camera
Should the toe in necessarily be the same with both speakers?
I have always had walls on both side that are equal, so yes under this circumstance which helps center imaging.
I don’t know for guys that have open walls, windows or other non equal attributes that bring on their own set of challenges I’m sure.
I spent 12 years at the Portsmouth Naval Shipyard.
I was based in San Diego and Pearl, with a few months in the yards in Vallejo and Bremerton
