Puma Cat
Definitely let us know how it turns out!
Will do.
And...look what just arrived: the USB-A and RJ45 VTX-Ag tails.
Et voila...
the USB tail on an Alpha CGC
the RJ45 tail on an Alpha CGC
Hi Stephen,
great reports from your end! This mirrors my experience from adding signal grounding to my Taiko Extreme. I had only done the standard grounding via the GND post. Then for fun I added another grounding cable to one of the free Ethernet ports not expecting much. I was pinching myself as I didn’t expect anything. As you described…more body, weight, expansiveness. Great! Then I remembered that Emile from Taiko recommended the USB port is the most effective choice. So switched to USB…and yeah … even better! Also Emile said you could try doing more than one signal ground and give it a try. So, I added the Ethernet back. Hell, that was like adding up the two individual effects!! Wohoooo!
As Caelin said in the interview with Mike, these digital devices by their very nature are quite dirty.
So for everyone with an Altaria and a capable digital source, please give it a try and connect a signal grounding cable… you might very much like the effect!![]()
Yes, that mirrors my experience as well. That's great that Taiko has a ground terminal on it. I wish all manufacturers installed these on their components. I just remembered that the forthcoming Lumin L2 has a ground terminal, also. So, good on ya Taiko and Lumin! :tup:
After installing the USB cable on the Mini Roon core, I just performed your experiment, but in reverse order: I installed the RJ45 tail on a Venom CGC cable and connected it to the Pace Router and obtained further improvements. Not quite of the magnitude of the USB tail in the Mini, but probably 75% of the improvement, but that's likely due to the this ground cable being a Venom instead an Alpha. The jump from the Venom to the Alpha ground cables is pretty notable, so for component connections, I've decided to standardize on Alpha ground cables.
Rememer, the noise does not ride down low, at what some folks refer to as the "noise floor", it rides ON TOP of the signal, as shown.
Just installing those tails yesterday, the presentation and overall audio quality took quite a notable jump forward. So, when it comes to noise, every bit helps.
So, that's consistent and concordant with your findings as well. :tup:
In conclusion, if folks have "remote server rooms", "network closets" etc., adding ground cables with the appropriate tails to the "networked devices", e.g. Roon cores, Taikos, Grimm, Pink Faun "music servers", etc., and Ethernet switches, routers, and the like, connecting them to a Gemini or Altaira for grounding pays big dividends.
It looks like there is a new grounding cable VENOM-X. There is a photo of it in the banner of the Shunyata home page but it's not listed in the product page.
Nice findings Pumacat. Is Gemini coming in an EU/Schuko version as well?
It’s been 6 months since I own one and just want to say Altaira should be the product of the year.
The experts may weigh in but in my opinion, I would ground both. The Altaira has multiple ground connections and both ‘boxes’ could have low levels of electrical noise in them.
Absolutely agree, the answer is "both".The experts may weigh in but in my opinion, I would ground both. The Altaira has multiple ground connections and both ‘boxes’ could have low levels of electrical noise in them.
I've seen this mentioned by you and others, including mention of the RH install as well.Yup. Fact is, everything that is powered...has noise. There is virtually no getting around this fact; at the end of the day, this is physics, after all. Moreover, one can never completely eliminate noise...at the very lowest "level" there will still be types of noise e.g., shot noise, etc. But, whatever one can do to reduce the level and impact of noise really helps, particularly for our high-end audio systems.
From my experience, folks should connect an Altaira to any ground terminal or unused "interface connection" they can. I find that the ground-plane noise decreases even further when you ground unused "ports", e.g. unused signal interface jacks (RCA & XLR), and USB, S/PDIF, AES/EBU ports, etc.
So, for example, I am running GCGs from the unused RCA and XLR jacks on the Constellation integrated, and unused USB, S/PDIF, and RCA inputs on the Lumin P1 (as well as the dedicated chassis ground terminal on the P1; thank you, Lumin.)
Also, if you can go "dual-mono" with two SG Altairas for each channel, L/R, for fully dual-mono amplification components e.g., amps & integrateds, etc., from Esoteric, Dart, Soulution, Constellation, CH, etc., etc.)...holy sh*t!
This is one area where quantifiable results and tests are not given. Only a "more is better" rationale is used.
As you know, I am a multi-zone Altaira SG-NR user and fan, also have plenty of other Shunyata gear and cables in my system for 20+ years, and have tested many configs for CG as well as SG. For SG, those configs included dual mono design components in the mix.
This is one area where I do not see the real reason for the premise or rigorous responses being given anywhere.
Let's remember, too, that there are dual mono configs for amps, DACs, etc, where L and R are 2 separate chassis, and further, there are dual-mono design components in a single chassis using separate internal sub-chassis and separated circuit topologies.
Given this (taken straight off the Altaira product page):
"Six Isolation Zones
ALTAIRA has six terminals that are each individually isolated from one another. Each terminal is designed to connect to a single component for best performance. Each zone and each component is therefore isolated from one another and from earth-ground common-mode noise."
For Signal Grounding, why is it then necessary to have 2 Altaira (for L and R)?
<snip>
Open to any new information and data on this....I don't understand the premise ("yet")![]()
All I can say, Mark, is that the improvements provided by going "dual-mono" with an SG Altaira for each channel, L/R, for my dual-mono Constellation integrated, were signficant. It wasn't a "subtle" improvement.
So, I'm going with the "empirical data". If possible, give it a try and see what you think.
Cheers and best regards.
