a.wayne
Moving Mass = Distortion
Not following your non specific posts , every driver has Mass and every speaker system architecture is usually a balancing act of compromises....
regards
regards
You are correct, just pointing out the compromise Magico has made in the S5 MKII, more deep bass, less midrange clarity. There is not much recorded music in the sub bass, 20Hz to 60Hz, but there is a lot of recorded music in the midrange, 250Hz to 4kHz.
Forgive me, but i'm a little bit perplexed by your reply Hiker. Myles B Astor and several others who attended RMAF remarked that the best midrange from loudspeakers at the show was from the Vandersteen 7Mk2, followed very closely by the Magico M3. Putting all other variables aside for a moment, the M3's graphene midrange driver is the best cone midrange drive in the world at the moment imho.You are correct, just pointing out the compromise Magico has made in the S5 MKII, more deep bass, less midrange clarity. There is not much recorded music in the sub bass, 20Hz to 60Hz, but there is a lot of recorded music in the midrange, 250Hz to 4kHz.
Yes and no,
Midrange fundamentals and timbre is affected by deep bass or lack of , so deep bass is essential in locking in real world performance, it's the difference between sounding real or sounding hi-fi. Now , i can agree , that operating in such a wide bandwidth for a small single driver would lead to higher thd at specific levels, again , by doing so there's the added touch of no xover in the critical midband and hence no phase shift. It's a compromise, specifically , a compromised that Magico felt was inherently superior to where they were before.
Yes and no,
regards ...
Good balanced post. Many speaker designers, over the years, have had to deal with the issue of preserving the important midrange. Klipsch, in their Pladdium speaker, chose to have the midrange driver handle the predominate 500Hz to 4kHz range. They chose to have a separate driver handle the frequencies below 500Hz. Magico, in their Ultimate speaker, chose to have three separate drivers handle the midrange. Marketing hype does not change the laws of science and physics.
Btw, to me low (sub) bass is below 40Hz, mid bass is from 40-80Hz, upper bass is from 80-160Hz, above this you are getting into the lower mids which is 160-320Hz. the midrange is from 320 to about 1KHz, from 1KHZ to 3KHz is the upper mids to me, this is also the presence region & where human hearing is the sharpest. Lower treble goes from 3KHz to 6KHz, regular treble from 6KHz to 12KHz & upper treble is anything above that.
Could you tell me where I can find Myles Astor's comments on RMAF 2016? I would like to see what he had to say.
Thanks, Ken
You are confusing all sorts of issues here. The last things you want to do is crossover anything at 500Hz, that is smack in the middle of the midrange. The reason horns are like that is due to their VERY limited band pass, you have to use more drivers, with appropriate size horns to keep the efficiency at a max (think about it as a short blanket, trying to cover a large bad). That is actually one of the major drawbacks horns suffer from. Totally not relevant in the S5 case.
Speaker efficiency is a result of it's sensitivity rating, 1m/2.83v/1w. Horn loaded diaphragms are up to 10 times more efficient than similar size direct-radiating cones. Since wave lengths emanating from direct-radiating cones are coupled directly with air (high impedance meeting low impedance) changes in frequency can result in harmful artifacts, e.g., Doppler distortion, that can be recognized by the ear. If designed properly, horns are virtually immune from these harmful effects.
Btw , there is no panacea in audio , Horns vs Direct radiator vs ESL vs Ribbons all will suffer from issue too long to post here, we all have our truth in reproduction, there is no World greatest , all will have strenghts and weakness ...
