u-sound
i think the idea is separating things.
not that i would understand roon...
How can you fix noisy P2P software with hardware? Hardware which is so CPU intensive, it adds yet more noise?
Apparently, using Roon Core on the Taiko doesn't result being a good idea in terms of sound quality.
Running Roon, which is really a computing hungry beast
Hi Mike,
Sorry, not sure I understand what you meen by P2P.
I suppose you're referring to Ethernet noise and noise related to computing-hungry software like the Roon Core.
Regarding Ethernet noise, that is pretty easy: ethernet over optic fibre. Lumin P1, Sonore Signature Rendu and a few others chose that path.
There are other options like audiophile switches: PhoenixNET, EtherRegen, etc.
The traffic generated by HiRes music, even DXD (LPCM 24/352.8), is almost nothing. So a network adapter doing 100Mbits is more than enough and won't generate a lot of noise on the streamer side.
Regarding computing-hungry software like the Roon Core, you can do nothing. The only thing to do is follow Roon Labs advice: put the server somewhere on the network, well away from the HiFi gear. And connect a very simple, yet very well designed, Roon Endpoint to the DAC.
Unfortunately, the only device I know that comes close to that is the Sonore Signature Rendu.
I believe that something with a different design, better much better power supply, a much better clock, etc., doing just one thing (Roon End Point) could, in terms of sound quality, outperform any top-notch server.
Unfortunately, such a Roon Endpoint does not exist.
Most people want more like having access to Qobuz, Tidal, etc. Storing music and serving it directly to the DAC without bothering about network-related issues, which is quite understandable... Hence versatile music servers.
I hope I didn't reply out of scope...:huh:
I just ordered the Soulution 760 DAC and Soulution 711 amplifier.
My music server is Roon Rock installed on a dedicated NUC based server.
That server is located somewhere in my network away from the HiFi.
I'm looking for a Roon End Point (transport only) to connect to the 760, whether USB or AES.
Most of the offerings are servers, which I don't need.
There aren't many transports-only available.
The options could be :
- Sonore Signature Rendu Optical SE
- Lumin U1
Is there anything else available?
The other option would be to stick with the LAN adapter included in the Soulution 760 and use rooUPnP as a RAAT to UPnP converter.
Is something else available ?
What are you views?
Thank you for your help,
Tom
Peer to peer network. Lots of network traffic = noise.
I’ve had several discussions with Antipodes recently (they are very interested in Suncoast, but I’m just not sure we have a need). They also place Roon way down the list of their favorites from a sonic perspective. It’s why Taiko is building their own software. The difference between TAS and Roon is night and day.
I love the Roon interface, but prefer the sound from TAS/aurender. We run all three in the store and I run Roon and Aurender at home. Switching back and forth is ear opening.
I would get the Taiko if you want Roon. That way you can switch back and forth and hear the difference. If you’re ok to give up sound quality for sorting, than at least you have both.
Any Roon-End Point that can output digital to your DAC should do the trick.
But if you don’t want to spend thousands for a component that comes with features that you don’t need, and if you feel comfortable doing some work yourself, you can always build a Roon End Point for about $120 (RAspberry Pi, HiFi Berry Pro+ HAT, Ropieee, case). FWIW, there several brand name products out there that sell for thousands that use RPi under the hood.
I wish it was that simple.
I like to tinker once in a while. Reminds me my youth.
And the Raspberry Pi ecosystem is a nice and cheap way to learn about software design. In my experience (and I did try), a Raspberry Pi does not outperform a well designed Roon Endpoint.
But it's fun!
One of my Pi boards : http://serra.se/pi.jpg
EDIT : out of curiosity, which brands using Raspberry Pi as their core boards are you referring to?
Both Roon Client and Roon Core both seem to use a relatively small amount of resources now, at least when not using any of the potentially compute-intensive operations like DSP.
How exactly is a CPU usage adding noise? And, on my Core Server, with both Roon Core and HQPlayer running there is a max of maybe, maybe 35% CPU usage. Basically the CPU is twiddling its thumbs. Again I say, how exactly is using 35% of an 8-core CPU adding noise into the system. And, attaching the server direct to the DAC is actually less noise because you are not sending your digital signal through all the network wiring (ethernet or even worse WiFi), Router, Switches, etc. Having the music store internal on the server and traveling through a single cable to the DAC is definitely the cleanest way and least possible noise addition.
Roon core is not a monster... it basically makes the computer sit there and do almost nothing... HQPlayer is in fact a monster but it still does not tax current equipment.
I believe we have different views about what causes noise and what is a heavy CPU load, and that's fine![]()
More powerful CPU creates more heat and making more noise.
This is a widely accepted fact.
Within reason and depending on use. If being push hard certainly, but Roon is not pushing them hard... but then again if more powerful CPUs cause issues why does the SGM Extreme Music Server (consider by many as the pinnacle of music servers) use dual 10-core, 20 thread CPUs... in other words full 40 threads.... some of the most powerful CPUs available...
This is Aurender’s principle for best sound. Others need more power CPU’s for applications like Roon.
Until you’ve tried an Aurender N20 against your best home made server and really listen to how shitty Roon sounds A/B, you won’t know.
send me an Aurender and I will be happy to do a complete and fair comparison
