maty
As I have not heard any I can not comment. I hope it is as good as they say.
Here is a link to Richard's site, he is the one that built one for me, Wisnon and Joe. Can't wait to get it.
The Sound of Aum
And specifically here
ELAC FS407, Chord QuteHD DAC, Chord QuteEX DAC, Chord Hugo DAC, Audiophilleo, Tortuga Audio, MG Audio Design, JOB 225
Hi everyone,
What do you think about TVC passive preamplifiers?
Music First (TVC) Passive Magnetic Pre amplifier
-> Music First Amplifiers [English]
The Django preamp
-> TNT Audio Django preamp Review [English]
Yes Sir! Mine should be here in a few days. Hopefully my Teddy Pardo ps will arrive sometime this week or next. Can't wait.
Hi Joe,
Where can I find more information on this preamp? Cannot find the price on the website. Would you recommend it with the Job?
Thanks!
Here is the website for the volume control:
Here is the Teddy Pardo ps I ordered:
Dual12 - 2x12V 1A Power Supply | Power Supplies | TeddyPardo
Talk to Richard Becker from Aum Acoustics
[email protected]
He's a super nice guy. The volume control he built for me will be here tomorrow and the ps sometime this week or next.
I can't keep up!
You gotta wait for the grand unveiling Mike!
I suspect Joe will have an instant classic....the 3 codes words are Gold, Silver and Platinum (wire)!
The Tilsbury doesn't look anywhere near as good the pot it basically a crap Chinese switch, ask around on the forum I know four people who that volume pot they all click, hum, stutter jump, pop at various positions after a bit of use. It has a nice case and appears to have a bypass option for a straight throughput, though doesn't appear to have a shunt to ground set-up so impedance will vary more with volume position...
An item is DACT Type SMD 21 Stepped Attenuator
inside contact is gold plate
short before break Type
I have got 10K / 20K / 50K and 100K in store
Contact terminology
In electronics, switches are classified according to the arrangement of their contacts. A pair of contacts is said to be "closed" when current can flow from one to the other. When the contacts are separated by an insulating air gap, they are said to be "open", and no current can flow between them at normal voltages. The terms "make" for closure of contacts and "break" for opening of contacts are also widely used.
In a switch where the contacts remain in one state unless actuated, such as a push-button switch, the contacts can either be normally open (abbreviated "n.o." or "no") until closed by operation of the switch, or normally closed ("n.c." or "nc") and opened by the switch action. A switch with both types of contact is called a changeover switch. These may be "make-before-break" ("MBB" or shorting) which momentarily connects both circuits, or may be "break-before-make" ("BBM" or non-shorting) which interrupts one circuit before closing the other.
