Pre-amp/DAC for JOB 225
Just received Job 2 pre on July 4. It went all the way from Switzerland to Canada in just2 days. Great product. More precise than my Mimesis 7 pre (1990) but the Mimesis 7 has the orginal glow and naturalness that the Pre 2 does not have. One complaint I let Job know of, is side screws to top cover were missing. All in all worth the money.
Goldmund even sent me missing screws express Switzerland to Canada in 3 days. Never could afford their extremed gear;their customer service has been knocked in the past; if it was bad sure has improved.
I use Schitt audio Saga passive/active (no gain in either mode), it uses one 6sn7 (or equivalent) dual triode for the no gain "tube buffer" mode. Usually I run it in buffer mode. It also has a switched resistor volume control. The tube mode adds just a touch of weight and drive compared to passive. It's a good single ended input/output preamp and works well with high gain single ended input Job. Schitt calls it a "reference level preamp disguised by its price", hell if I know what the reference is, but at $350 I'm sure not complaining. They match up well to make a nice musical sound, some but not all of the hi fi qualifier boxes get ticked, Yet there is certain rightness to the whole. If you gotta have the full size high end unit with all the trimmings, probably Saga won't do, but I guess you could say the same thing about the Job 225.
